Installation & Licensing
New Member
dlogsdon
Message 1 of 3 (355 Views)
Installation error
355 Views, 2 Replies
12-21-2012 12:03 PM
Having trouble installing Autocad 2013 log posted.
2012/12/21:13:11:36 eharvey EHARVEY-PC PageOpen InstallCompleteDialog   2012/12/21:13:14:06 eharvey EHARVEY-PC === Setup ended ===
2012/12/21:13:17:40 eharvey EHARVEY-PC === Setup started on EHARVEY-PC by eharvey === 2012/12/21:13:17:40 eharvey EHARVEY-PC Launch 2012/12/21:13:19:11 eharvey EHARVEY-PC === Setup ended ===
2012/12/21:13:17:52 eharvey EHARVEY-PC === Setup started on EHARVEY-PC by eharvey === 2012/12/21:13:17:52 eharvey EHARVEY-PC Launch 2012/12/21:13:19:11 eharvey EHARVEY-PC PageOpen LaunchDialog   2012/12/21:13:19:28 eharvey EHARVEY-PC PageOpen LicenseDialog   2012/12/21:13:19:32 eharvey EHARVEY-PC PageOpen ProductInfoDialog   2012/12/21:13:20:34 eharvey EHARVEY-PC PageOpen ProductSelectionDialog2   2012/12/21:13:23:59 eharvey EHARVEY-PC PageOpen FullProgressDialog   2012/12/21:13:23:59 eharvey EHARVEY-PC Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/21:13:24:43 eharvey EHARVEY-PC Install DirectX Runtime Succeeded  2012/12/21:13:24:43 eharvey EHARVEY-PC Installing AutoCAD® 2013:  TRANSFORMS="D:\x64\en-us\acad\acad.mst;C:\Users\eharvey\AppData\Local\Temp\_AI3EF2.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/21:13:26:35 eharvey EHARVEY-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2012/12/21:13:26:35 eharvey EHARVEY-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2012/12/21:13:26:39 eharvey EHARVEY-PC PageOpen InstallCompleteDialog   2012/12/21:13:54:34 eharvey EHARVEY-PC === Setup ended ===
2012/12/21:13:56:22 eharvey EHARVEY-PC === Setup started on EHARVEY-PC by eharvey === 2012/12/21:13:56:22 eharvey EHARVEY-PC Launch 2012/12/21:13:56:37 eharvey EHARVEY-PC === Setup ended ===
2012/12/21:13:56:32 eharvey EHARVEY-PC === Setup started on EHARVEY-PC by eharvey === 2012/12/21:13:56:32 eharvey EHARVEY-PC Launch 2012/12/21:13:56:37 eharvey EHARVEY-PC PageOpen LaunchDialog   2012/12/21:13:56:41 eharvey EHARVEY-PC PageOpen LicenseDialog   2012/12/21:13:56:46 eharvey EHARVEY-PC PageOpen ProductInfoDialog   2012/12/21:13:56:54 eharvey EHARVEY-PC PageOpen ProductSelectionDialog2   2012/12/21:13:57:07 eharvey EHARVEY-PC PageOpen FullProgressDialog   2012/12/21:13:57:07 eharvey EHARVEY-PC Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/21:13:57:34 eharvey EHARVEY-PC Install DirectX Runtime Succeeded  2012/12/21:13:57:35 eharvey EHARVEY-PC Installing AutoCAD® 2013:  TRANSFORMS="D:\x64\en-us\acad\acad.mst;C:\Users\eharvey\AppData\Local\Temp\_AIAC17.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/21:13:59:16 eharvey EHARVEY-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2012/12/21:13:59:17 eharvey EHARVEY-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
pendean
Message 2 of 3 (328 Views)
Re: Installation error
12-24-2012 06:36 AM in reply to: dlogsdon
TravisNave
Message 3 of 3 (289 Views)
12-26-2012 11:19 AM in reply to: dlogsdon
First copy your installation files from your D:\ to a folder on your C:\.  Make sure that you are installing with local admin rights, UAC off, and anti-virus disabled.  Also, if you have any other flavor of AutoCAD 2013, you might get this error.  So no need to install vanilla AutoCAD 2013 if you have already installed it from other Suite like Mechanical, Architectural, etc.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
