Installation & Licensing
484 Views, 2 Replies
Installation error
Having trouble installing Autocad 2013 log posted.
2012/12/21:13:11:36 eharvey EHARVEY-PC PageOpen InstallCompleteDialog   2012/12/21:13:14:06 eharvey EHARVEY-PC === Setup ended ===
2012/12/21:13:17:40 eharvey EHARVEY-PC === Setup started on EHARVEY-PC by eharvey === 2012/12/21:13:17:40 eharvey EHARVEY-PC Launch 2012/12/21:13:19:11 eharvey EHARVEY-PC === Setup ended ===
2012/12/21:13:17:52 eharvey EHARVEY-PC === Setup started on EHARVEY-PC by eharvey === 2012/12/21:13:17:52 eharvey EHARVEY-PC Launch 2012/12/21:13:19:11 eharvey EHARVEY-PC PageOpen LaunchDialog   2012/12/21:13:19:28 eharvey EHARVEY-PC PageOpen LicenseDialog   2012/12/21:13:19:32 eharvey EHARVEY-PC PageOpen ProductInfoDialog   2012/12/21:13:20:34 eharvey EHARVEY-PC PageOpen ProductSelectionDialog2   2012/12/21:13:23:59 eharvey EHARVEY-PC PageOpen FullProgressDialog   2012/12/21:13:23:59 eharvey EHARVEY-PC Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/21:13:24:43 eharvey EHARVEY-PC Install DirectX Runtime Succeeded  2012/12/21:13:24:43 eharvey EHARVEY-PC Installing AutoCAD® 2013:  TRANSFORMS="D:\x64\en-us\acad\acad.mst;C:\Users\eharvey\AppData\Local\Temp\_AI3EF2.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/21:13:26:35 eharvey EHARVEY-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2012/12/21:13:26:35 eharvey EHARVEY-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2012/12/21:13:26:39 eharvey EHARVEY-PC PageOpen InstallCompleteDialog   2012/12/21:13:54:34 eharvey EHARVEY-PC === Setup ended ===
2012/12/21:13:56:22 eharvey EHARVEY-PC === Setup started on EHARVEY-PC by eharvey === 2012/12/21:13:56:22 eharvey EHARVEY-PC Launch 2012/12/21:13:56:37 eharvey EHARVEY-PC === Setup ended ===
2012/12/21:13:56:32 eharvey EHARVEY-PC === Setup started on EHARVEY-PC by eharvey === 2012/12/21:13:56:32 eharvey EHARVEY-PC Launch 2012/12/21:13:56:37 eharvey EHARVEY-PC PageOpen LaunchDialog   2012/12/21:13:56:41 eharvey EHARVEY-PC PageOpen LicenseDialog   2012/12/21:13:56:46 eharvey EHARVEY-PC PageOpen ProductInfoDialog   2012/12/21:13:56:54 eharvey EHARVEY-PC PageOpen ProductSelectionDialog2   2012/12/21:13:57:07 eharvey EHARVEY-PC PageOpen FullProgressDialog   2012/12/21:13:57:07 eharvey EHARVEY-PC Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/21:13:57:34 eharvey EHARVEY-PC Install DirectX Runtime Succeeded  2012/12/21:13:57:35 eharvey EHARVEY-PC Installing AutoCAD® 2013:  TRANSFORMS="D:\x64\en-us\acad\acad.mst;C:\Users\eharvey\AppData\Local\Temp\_AIAC17.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/21:13:59:16 eharvey EHARVEY-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2012/12/21:13:59:17 eharvey EHARVEY-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2 REPLIES 2
pendean
TravisNave
First copy your installation files from your D:\ to a folder on your C:\.  Make sure that you are installing with local admin rights, UAC off, and anti-virus disabled.  Also, if you have any other flavor of AutoCAD 2013, you might get this error.  So no need to install vanilla AutoCAD 2013 if you have already installed it from other Suite like Mechanical, Architectural, etc.
Autodesk Forums:
Administrator Productivity
