When trying to download Inventor, I came across several errors or a peroid of a couple days and I've tried everything it seems like and Finally need help. Everytime I try and download it something always messes up in the install or downlaod and it doesn't work. I have thoroughly gone through and deleted all the program files and the registery stuff, turned off my anti-virus programs and still no luck. I have the log file if thats needed, but heres a screen shot of the most recent one. Thanks for any help!
Hi Allen,
Can you confirm that you've tried all of the steps detailed in the Error 1937 solution?
If so, I would definitely recommend attaching your installation log.
Nope, I haven't tried this solution yet, should I go through and delete everything as well as this or should I just try and redownload and reinstall?
I would recommend starting from a clean slate + the suggestions mentioned in the link above. To help do so, you may want to check out our clean uninstall post linked here.
Ok, I did that and it worked to an extent. Everything downloaded but when I go to run Inventer, it crashes after I try and make a new project or whatever. It sent an error report and I got back a messege saying I needed a maintenance download, so I downloaded it and installed it but it didn't seem to work. I tried to reinstall it but I got this error message a long with another.
