I am unable to install the Inventor 2015
kindly help me out with the problem.
i am attaching the installation log file.
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
