Installation & Licensing
Installation error autocad 2014 and 3ds Max
2 REPLIES 2
jeffrey_pieterse
289 Views, 2 Replies
Recently i tried to install autocad and 3ds Max student versions.
Problem is when i tried installing i got with both programs an error saying connection failure so i desided to cancel the installation and try it again tommorow.
When i tried installing again i could not install autocad because it was ''already installed'',well it was not fully installed so i go to the control panel and uninstall everything autodesk already installed.
Now i tried again to install autocad and it still said it was already installed so i just looked for every file i could find and just deleted them.
Still the installation setup said autocad was installed, so i decided to do a windows recovery to 6 days earlier so there could be no way something from autodesk would be installed.
Now after the recovery i tried again to install the program but it said something different now.
after i clicked ok i could still choose if i wanted to install the program so i clicked install.
then this popped up:
i clicked OK again and the window just closed and i cant install the program now.
So its just a complete mess now can anyone help me with this?
2 REPLIES 2
aaronhai
in reply to: jeffrey_pieterse
Hi jeffrey_pieterse,
Welcome to Auodesk Forum.
Please try to un-install or remove AutoCAD using Microsoft Fix-It utility (Win 7 / Win 8).
Thank you.
Aaron Hai
jeffrey_pieterse
in reply to: aaronhai
Already tried fixit but it did not work autocad was not showing in the list of programs to uninstall.
I tried it for the second time when you mentioned it and i cant find the program on the microsoft site.
Administrator Productivity
