Here is my error log. Any help greatly appreciated.
2014/12/23:00:06:19 New MATTPC === Setup started on MATTPC by New ===
2014/12/23:00:06:19 New MATTPC Path_Length: 148
2014/12/23:00:06:19 New MATTPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_en-US
2014/12/23:00:06:19 New MATTPC Launch
2014/12/23:00:06:19 New MATTPC CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_e... /SN 900-45560138 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/12/23:00:06:19 New MATTPC Current Directory C:\Users\New\AppData\Local\Temp\_AID97F.tmp
2014/12/23:00:06:20 New MATTPC === Setup ended ===
2014/12/23:00:06:19 New MATTPC [Error: 1060] The specified service does not exist as an installed service.
2014/12/23:00:06:19 New MATTPC [Error: 6] The handle is invalid.
2014/12/23:00:06:19 New MATTPC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2014/12/23:00:06:20 New MATTPC PageOpen LaunchDialog
2014/12/23:00:06:23 New MATTPC PageOpen LicenseDialog
2014/12/23:00:06:23 New MATTPC PageOpen ProductSelectionDialog2
2014/12/23:00:06:32 New MATTPC PageOpen LicenseDialog
2014/12/23:00:06:32 New MATTPC PageOpen LaunchDialog
2014/12/23:00:06:35 New MATTPC PageOpen LicenseDialog
2014/12/23:00:06:35 New MATTPC PageOpen ProductInfoDialog
2014/12/23:00:06:35 New MATTPC PageOpen ProductSelectionDialog2
2014/12/23:00:07:19 New MATTPC PageOpen FullProgressDialog
2014/12/23:00:07:19 New MATTPC Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2014/12/23:00:07:19 New MATTPC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/23:00:07:30 New MATTPC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/23:00:07:30 New MATTPC Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2014/12/23:00:07:30 New MATTPC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/23:00:07:41 New MATTPC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/23:00:07:41 New MATTPC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2014/12/23:00:07:41 New MATTPC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/23:00:07:48 New MATTPC Install DirectX® Runtime Succeeded
2014/12/23:00:07:48 New MATTPC Download Skipped CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2014/12/23:00:07:48 New MATTPC Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:00:07:55 New MATTPC Install Autodesk® Material Library 2015 Succeeded
2014/12/23:00:07:55 New MATTPC Download Skipped CMILB http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILB.t...
2014/12/23:00:07:55 New MATTPC Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:00:08:01 New MATTPC Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/12/23:00:08:01 New MATTPC Download Skipped CMILM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CMILM.t...
2014/12/23:00:08:01 New MATTPC Installing Autodesk® Material Library 2015 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:00:08:19 New MATTPC Install Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2014/12/23:00:08:19 New MATTPC Download Skipped MAX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/MAX.tar...
2014/12/23:00:08:21 New MATTPC Installing Autodesk® 3ds Max 2015: TRANSFORMS="C:\Users\New\AppData\Local\Temp\_AID97F.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" INSTALLDIR="E:\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:00:08:40 New MATTPC Install Autodesk® 3ds Max 2015 Failed Installation aborted, Result=1603
2014/12/23:00:08:47 New MATTPC Rollback Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2014/12/23:00:08:54 New MATTPC Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/12/23:00:09:06 New MATTPC Rollback Autodesk® Material Library 2015 Succeeded
2014/12/23:00:09:06 New MATTPC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/23:00:09:06 New MATTPC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/12/23:00:09:06 New MATTPC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/12/23:00:09:06 New MATTPC PageOpen InstallCompleteDialog
2014/12/23:09:50:01 New MATTPC [Error: 6] The handle is invalid.
2014/12/23:09:50:01 New MATTPC === Setup ended ===
2014/12/23:09:55:26 New MATTPC === Setup started on MATTPC by New ===
2014/12/23:09:55:26 New MATTPC Path_Length: 148
2014/12/23:09:55:26 New MATTPC Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/12/23:09:55:26 New MATTPC Launch
2014/12/23:09:55:26 New MATTPC CommandLine
2014/12/23:09:55:26 New MATTPC Current Directory C:\Users\New\AppData\Local\Temp\_AI33E9.tmp
2014/12/23:09:55:28 New MATTPC === Setup ended ===
2014/12/23:09:55:26 New MATTPC [Error: 1060] The specified service does not exist as an installed service.
2014/12/23:09:55:26 New MATTPC [Error: 6] The handle is invalid.
2014/12/23:09:55:27 New MATTPC PageOpen LaunchDialog
2014/12/23:09:55:37 New MATTPC PageOpen LicenseDialog
2014/12/23:09:55:40 New MATTPC PageOpen ProductInfoDialog
2014/12/23:09:57:04 New MATTPC PageOpen ProductSelectionDialog2
2014/12/23:09:57:38 New MATTPC PageOpen FullProgressDialog
2014/12/23:09:57:38 New MATTPC Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/23:09:57:49 New MATTPC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/12/23:09:57:49 New MATTPC Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/23:09:57:59 New MATTPC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/12/23:09:57:59 New MATTPC Installing DirectX® Runtime: "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/12/23:09:58:07 New MATTPC Install DirectX® Runtime Succeeded
2014/12/23:09:58:07 New MATTPC Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:09:58:14 New MATTPC Install Autodesk® Material Library 2015 Succeeded
2014/12/23:09:58:14 New MATTPC Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:09:58:19 New MATTPC Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/12/23:09:58:19 New MATTPC Installing Autodesk® Material Library 2015 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:09:58:33 New MATTPC Install Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2014/12/23:09:58:34 New MATTPC Installing Autodesk® 3ds Max 2015: TRANSFORMS="C:\Users\New\AppData\Local\Temp\_AI33E9.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" INSTALLDIR="E:\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:09:58:54 New MATTPC Install Autodesk® 3ds Max 2015 Failed Installation aborted, Result=1603
2014/12/23:09:59:01 New MATTPC Rollback Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2014/12/23:09:59:08 New MATTPC Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/12/23:09:59:20 New MATTPC Rollback Autodesk® Material Library 2015 Succeeded
2014/12/23:09:59:20 New MATTPC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/12/23:09:59:20 New MATTPC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/12/23:09:59:20 New MATTPC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/12/23:09:59:20 New MATTPC PageOpen InstallCompleteDialog
2014/12/23:10:04:19 New MATTPC [Error: 6] The handle is invalid.
2014/12/23:10:04:19 New MATTPC === Setup ended ===
2014/12/23:10:07:07 New MATTPC === Setup started on MATTPC by New ===
2014/12/23:10:07:07 New MATTPC Path_Length: 148
2014/12/23:10:07:07 New MATTPC Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/12/23:10:07:07 New MATTPC Launch
2014/12/23:10:07:07 New MATTPC CommandLine
2014/12/23:10:07:07 New MATTPC Current Directory C:\Users\New\AppData\Local\Temp\_AIE7CD.tmp
2014/12/23:10:07:12 New MATTPC === Setup ended ===
2014/12/23:10:07:08 New MATTPC === Setup started on MATTPC by New ===
2014/12/23:10:07:08 New MATTPC Path_Length: 148
2014/12/23:10:07:08 New MATTPC Current Directory C:\Users\New\AppData\Local\Temp\_AIE7CD.tmp
2014/12/23:10:07:08 New MATTPC Launch
2014/12/23:10:07:08 New MATTPC [Error: 1060] The specified service does not exist as an installed service.
2014/12/23:10:07:08 New MATTPC [Error: 6] The handle is invalid.
2014/12/23:10:07:12 New MATTPC PageOpen LaunchDialog
2014/12/23:10:07:17 New MATTPC PageOpen LicenseDialog
2014/12/23:10:07:17 New MATTPC PageOpen ProductSelectionDialog2
2014/12/23:10:07:23 New MATTPC PageOpen FullProgressDialog
2014/12/23:10:07:23 New MATTPC Installing Autodesk® 3ds Max 2015 SDK: TRANSFORMS="C:\Users\New\AppData\Local\Temp\_AIE7CD.tmp\x64\Tools\MAXSDK\SDK_3DSMAX2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2015 SDK\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:10:07:39 New MATTPC Install Autodesk® 3ds Max 2015 SDK Succeeded
2014/12/23:10:07:39 New MATTPC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/23:10:07:39 New MATTPC Install Network License Manager Succeeded
2014/12/23:10:07:39 New MATTPC PageOpen InstallCompleteDialog
2014/12/23:10:07:44 New MATTPC [Error: 6] The handle is invalid.
2014/12/23:10:07:44 New MATTPC === Setup ended ===
2014/12/23:10:16:44 New MATTPC === Setup started on MATTPC by New ===
2014/12/23:10:16:44 New MATTPC Path_Length: 148
2014/12/23:10:16:44 New MATTPC Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/12/23:10:16:44 New MATTPC Launch
2014/12/23:10:16:44 New MATTPC CommandLine
2014/12/23:10:16:44 New MATTPC Current Directory C:\Users\New\AppData\Local\Temp\_AIB5F4.tmp
2014/12/23:10:17:00 New MATTPC === Setup ended ===
2014/12/23:10:16:56 New MATTPC === Setup started on MATTPC by New ===
2014/12/23:10:16:56 New MATTPC Path_Length: 148
2014/12/23:10:16:56 New MATTPC Current Directory C:\Users\New\AppData\Local\Temp\_AIB5F4.tmp
2014/12/23:10:16:56 New MATTPC Launch
2014/12/23:10:16:56 New MATTPC [Error: 1060] The specified service does not exist as an installed service.
2014/12/23:10:16:56 New MATTPC [Error: 6] The handle is invalid.
2014/12/23:10:17:00 New MATTPC PageOpen LaunchDialog
2014/12/23:10:17:02 New MATTPC PageOpen LicenseDialog
2014/12/23:10:17:05 New MATTPC PageOpen ProductInfoDialog
2014/12/23:10:17:42 New MATTPC PageOpen ProductSelectionDialog2
2014/12/23:10:17:57 New MATTPC PageOpen FullProgressDialog
2014/12/23:10:17:57 New MATTPC Installing Microsoft Visual C++ 2005 Redistributable (x86): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\New\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/12/23:10:18:01 New MATTPC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/12/23:10:18:01 New MATTPC Installing Microsoft Visual C++ 2005 Redistributable (x64): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\New\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/12/23:10:18:05 New MATTPC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
2014/12/23:10:18:05 New MATTPC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Hello. If this is still a problem, I would uninstall the Microsoft C++ redistributables from the machine before you run your install.
If you do not have one already, download a full copy of the installer first:
Thank you for taking part in our community!
