Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Installation error 1603, AutoCAD Mechanical 2015, Windows 8.1 pro, academic
4 REPLIES 4
ps.swiezawski
1288 Views, 4 Replies
Hi
I've tried many hints and I still can't instal AutoCAD Mechanical 2015. I have install files on hard drive.
Things, which I've tried are listed below:
1) reinstalling net framework and visual c++,
2) edit setup.ini file (removing vcred, dotnet - according to posts on this forum),
3) installing as administrator with disabled UAC and anty-virus,
4) removing registry by CCleaner software
I still haven't found a solution. I'm attaching log from the install, maybe someone will help me. I suppose that there's no error due to net framework or visual c++. Log file shows, that installation for these files was succeeded. The error appears when installing ACAD. Please, correct me if I'm wrong.
This case is urgent due to my dissertation project. Could yoy please help me? šŸ™‚
2014/8/11:18:44:54    Administrator    LAPTSON    === Setup started on LAPTSON by Administrator ===
2014/8/11:18:44:54    Administrator    LAPTSON    Path_Length: 157
2014/8/11:18:44:54    Administrator    LAPTSON    Current Directory D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm
2014/8/11:18:44:54    Administrator    LAPTSON    Launch
2014/8/11:18:44:54    Administrator    LAPTSON    CommandLine
2014/8/11:18:44:54    Administrator    LAPTSON    Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI58F8.tmp
2014/8/11:18:44:58    Administrator    LAPTSON    === Setup ended ===
2014/8/11:18:44:55    Administrator    LAPTSON    === Setup started on LAPTSON by Administrator ===
2014/8/11:18:44:55    Administrator    LAPTSON    Path_Length: 157
2014/8/11:18:44:55    Administrator    LAPTSON    Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI58F8.tmp
2014/8/11:18:44:55    Administrator    LAPTSON    Launch
2014/8/11:18:44:55    Administrator    LAPTSON    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI58F8.tmp\Setup\AcSetup.dll
2014/8/11:18:44:55    Administrator    LAPTSON    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/11:18:44:57    Administrator    LAPTSON    Install    CustomCallback    Info    Invoking custom callback for details: [VAULT] CB_FUNC=CBVaultInfoMessage CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI58F8.tmp\Setup\AcSetup.dll
2014/8/11:18:44:57    Administrator    LAPTSON    Install    CustomCallback    Info    Custom callback response: Status=1 INFO Title= Message=If you are a Subscription Customer, you can download Vault Basic (server and client) from Autodesk Subscription Center.
If you are not a Subscription Customer, you can download from: URLTitle=https://accounts.autodesk.com URLLink=https://accounts.autodesk.com
2014/8/11:18:44:58    Administrator    LAPTSON    PageOpen    LaunchDialog
2014/8/11:18:45:03    Administrator    LAPTSON    === Setup ended ===
2014/8/11:18:45:06    Administrator    LAPTSON    === Setup started on LAPTSON by Administrator ===
2014/8/11:18:45:06    Administrator    LAPTSON    Path_Length: 157
2014/8/11:18:45:06    Administrator    LAPTSON    Current Directory D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm
2014/8/11:18:45:06    Administrator    LAPTSON    Launch
2014/8/11:18:45:06    Administrator    LAPTSON    CommandLine
2014/8/11:18:45:06    Administrator    LAPTSON    Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp
2014/8/11:18:45:07    Administrator    LAPTSON    === Setup ended ===
2014/8/11:18:45:06    Administrator    LAPTSON    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp\Setup\AcSetup.dll
2014/8/11:18:45:06    Administrator    LAPTSON    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/11:18:45:07    Administrator    LAPTSON    Install    CustomCallback    Info    Invoking custom callback for details: [VAULT] CB_FUNC=CBVaultInfoMessage CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp\Setup\AcSetup.dll
2014/8/11:18:45:07    Administrator    LAPTSON    Install    CustomCallback    Info    Custom callback response: Status=1 INFO Title= Message=If you are a Subscription Customer, you can download Vault Basic (server and client) from Autodesk Subscription Center.
2014/8/11:18:45:08    Administrator    LAPTSON    PageOpen    LaunchDialog
2014/8/11:18:45:09    Administrator    LAPTSON    PageOpen    LicenseDialog
2014/8/11:18:45:11    Administrator    LAPTSON    PageOpen    ProductInfoDialog
2014/8/11:18:45:26    Administrator    LAPTSON    PageOpen    ProductSelectionDialog2
2014/8/11:18:45:49    Administrator    LAPTSON    PageOpen    FullProgressDialog
2014/8/11:18:45:49    Administrator    LAPTSON    Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/8/11:18:45:52    Administrator    LAPTSON    Install    Microsoft Visual C++ 2012 Redistributable (x86) Update 4    Succeeded
2014/8/11:18:45:52    Administrator    LAPTSON    Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/8/11:18:45:52    Administrator    LAPTSON    Install    Microsoft Visual C++ 2012 Redistributable (x64) Update 4    Succeeded
2014/8/11:18:45:52    Administrator    LAPTSON    Installing DirectX Runtime: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/11:18:46:00    Administrator    LAPTSON    Install    DirectX Runtime    Succeeded
2014/8/11:18:46:00    Administrator    LAPTSON    Installing Autodesk Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:46:20    Administrator    LAPTSON    Install    Autodesk Material Library 2015    Succeeded
2014/8/11:18:46:20    Administrator    LAPTSON    Installing Autodesk Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:46:37    Administrator    LAPTSON    Install    Autodesk Material Library 2015 - Base Image Library    Succeeded
2014/8/11:18:46:38    Administrator    LAPTSON    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:46:41    Administrator    LAPTSON    Install    Autodesk Content Service    Succeeded
2014/8/11:18:46:41    Administrator    LAPTSON    Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:46:42    Administrator    LAPTSON    Install    Autodesk Content Service Language Pack    Succeeded
2014/8/11:18:46:42    Administrator    LAPTSON    Installing AutodeskĀ® AutoCADĀ® Mechanical 2015:  TRANSFORMS="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\x64\en-us\acadm\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:50:03    Administrator    LAPTSON    Install    AutodeskĀ® AutoCADĀ® Mechanical 2015    Failed    Installation aborted, Result=1603
2014/8/11:18:50:04    Administrator    LAPTSON    Rollback    Autodesk Content Service Language Pack    Succeeded
2014/8/11:18:50:06    Administrator    LAPTSON    Rollback    Autodesk Content Service    Succeeded
2014/8/11:18:50:13    Administrator    LAPTSON    Rollback    Autodesk Material Library 2015 - Base Image Library    Succeeded
2014/8/11:18:50:27    Administrator    LAPTSON    Rollback    Autodesk Material Library 2015    Succeeded
2014/8/11:18:50:27    Administrator    LAPTSON    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2014/8/11:18:50:27    Administrator    LAPTSON    Rollback    Microsoft Visual C++ 2012 Redistributable (x64) Update 4    Failed    Failure is ignored, Result=1619
2014/8/11:18:50:27    Administrator    LAPTSON    Rollback    Microsoft Visual C++ 2012 Redistributable (x86) Update 4    Failed    Failure is ignored, Result=1619
2014/8/11:18:50:28    Administrator    LAPTSON    PageOpen    InstallCompleteDialog
2014/8/11:18:51:56    Administrator    LAPTSON    === Setup ended ===
2014/8/11:18:54:46    Administrator    LAPTSON    === Setup started on LAPTSON by Administrator ===
2014/8/11:18:54:46    Administrator    LAPTSON    Path_Length: 157
2014/8/11:18:54:46    Administrator    LAPTSON    Current Directory D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm
2014/8/11:18:54:46    Administrator    LAPTSON    Launch
2014/8/11:18:54:46    Administrator    LAPTSON    CommandLine
2014/8/11:18:54:46    Administrator    LAPTSON    Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp
2014/8/11:18:54:48    Administrator    LAPTSON    === Setup ended ===
2014/8/11:18:54:47    Administrator    LAPTSON    === Setup started on LAPTSON by Administrator ===
2014/8/11:18:54:47    Administrator    LAPTSON    Path_Length: 157
2014/8/11:18:54:47    Administrator    LAPTSON    Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp
2014/8/11:18:54:47    Administrator    LAPTSON    Launch
2014/8/11:18:54:47    Administrator    LAPTSON    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp\Setup\AcSetup.dll
2014/8/11:18:54:47    Administrator    LAPTSON    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/11:18:54:48    Administrator    LAPTSON    Install    CustomCallback    Info    Invoking custom callback for details: [VAULT] CB_FUNC=CBVaultInfoMessage CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp\Setup\AcSetup.dll
2014/8/11:18:54:48    Administrator    LAPTSON    Install    CustomCallback    Info    Custom callback response: Status=1 INFO Title= Message=If you are a Subscription Customer, you can download Vault Basic (server and client) from Autodesk Subscription Center.
2014/8/11:18:54:48    Administrator    LAPTSON    PageOpen    LaunchDialog
2014/8/11:18:54:50    Administrator    LAPTSON    PageOpen    LicenseDialog
2014/8/11:18:54:54    Administrator    LAPTSON    PageOpen    ProductInfoDialog
2014/8/11:18:55:01    Administrator    LAPTSON    PageOpen    ProductSelectionDialog2
2014/8/11:18:55:45    Administrator    LAPTSON    PageOpen    FullProgressDialog
2014/8/11:18:55:45    Administrator    LAPTSON    Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/8/11:18:55:46    Administrator    LAPTSON    Install    Microsoft Visual C++ 2012 Redistributable (x86) Update 4    Succeeded
2014/8/11:18:55:46    Administrator    LAPTSON    Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/8/11:18:55:46    Administrator    LAPTSON    Install    Microsoft Visual C++ 2012 Redistributable (x64) Update 4    Succeeded
2014/8/11:18:55:46    Administrator    LAPTSON    Installing DirectX Runtime: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/8/11:18:55:50    Administrator    LAPTSON    Install    DirectX Runtime    Succeeded
2014/8/11:18:55:50    Administrator    LAPTSON    Installing Autodesk Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:55:56    Administrator    LAPTSON    Install    Autodesk Material Library 2015    Succeeded
2014/8/11:18:55:56    Administrator    LAPTSON    Installing Autodesk Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:56:02    Administrator    LAPTSON    Install    Autodesk Material Library 2015 - Base Image Library    Succeeded
2014/8/11:18:56:02    Administrator    LAPTSON    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:56:04    Administrator    LAPTSON    Install    Autodesk Content Service    Succeeded
2014/8/11:18:56:04    Administrator    LAPTSON    Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:56:06    Administrator    LAPTSON    Install    Autodesk Content Service Language Pack    Succeeded
2014/8/11:18:56:06    Administrator    LAPTSON    Installing AutodeskĀ® AutoCADĀ® Mechanical 2015:  TRANSFORMS="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\x64\en-us\acadm\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\CAD_CAE\AutoCAD Mechanical 2015\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/8/11:18:57:39    Administrator    LAPTSON    Install    AutodeskĀ® AutoCADĀ® Mechanical 2015    Failed    Installation aborted, Result=1603
2014/8/11:18:57:40    Administrator    LAPTSON    Rollback    Autodesk Content Service Language Pack    Succeeded
2014/8/11:18:57:41    Administrator    LAPTSON    Rollback    Autodesk Content Service    Succeeded
2014/8/11:18:57:47    Administrator    LAPTSON    Rollback    Autodesk Material Library 2015 - Base Image Library    Succeeded
2014/8/11:18:57:57    Administrator    LAPTSON    Rollback    Autodesk Material Library 2015    Succeeded
2014/8/11:18:57:57    Administrator    LAPTSON    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2014/8/11:18:57:57    Administrator    LAPTSON    Rollback    Microsoft Visual C++ 2012 Redistributable (x64) Update 4    Failed    Failure is ignored, Result=1619
2014/8/11:18:57:57    Administrator    LAPTSON    Rollback    Microsoft Visual C++ 2012 Redistributable (x86) Update 4    Failed    Failure is ignored, Result=1619
4 REPLIES 4
TravisNave
in reply to: ps.swiezawski
Which drive is your D:\ drive?
Also, never use CCleaner.  It is very bad.
Autodesk Forums:
ps.swiezawski
in reply to: TravisNave
"D" drive is not a system partition. Previously I've tried to install from "C" (system partition)
I haven't found a solution. Any ideas?
What about net framework? I'm afraid I might have a mess. What should I do for proper reinstalling? NET Framework Cleanup Tool didnt' delete net framework.
miroko
We are having same problem.
Tried massess of different 'solutions'.
Without antivirus, without UAC, creating deployment without service packs, creating deployment on different machines, making shorter deployment paths, uninstalling some windows updates, uninstaling net frameworks, modifying deployment, etc.....
And all the time we have the same problem.
Were you able to solve it ?
regards
miroko
Administrator Productivity
