Hi, i can´t find a way to install the DesignSuite 2012.
Here is the log-file:
2013/1/17:11:58:24 cwimmer WS-CWIM === Setup started on WS-CWIM by cwimmer === 2013/1/17:11:58:24 cwimmer WS-CWIM Launch 2013/1/17:11:58:32 cwimmer WS-CWIM PageOpen LaunchDialog 2013/1/17:12:00:26 cwimmer WS-CWIM PageOpen LicenseDialog 2013/1/17:12:00:36 cwimmer WS-CWIM PageOpen ProductInfoDialog 2013/1/17:12:01:12 cwimmer WS-CWIM PageOpen ProductSelectionDialog2 2013/1/17:12:01:14 cwimmer WS-CWIM PageOpen FullProgressDialog 2013/1/17:12:01:14 cwimmer WS-CWIM Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1031.exe /q 2013/1/17:12:02:09 cwimmer WS-CWIM Install .NET Framework Runtime 4.0 Language Pack Succeeded 2013/1/17:12:02:09 cwimmer WS-CWIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/1/17:12:02:12 cwimmer WS-CWIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2013/1/17:12:02:12 cwimmer WS-CWIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/1/17:12:02:16 cwimmer WS-CWIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/1/17:12:02:16 cwimmer WS-CWIM Installing DirectX Runtime: C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/17:12:04:05 cwimmer WS-CWIM Install DirectX Runtime Succeeded 2013/1/17:12:04:05 cwimmer WS-CWIM Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:04:08 cwimmer WS-CWIM Install FaroSDK Succeeded 2013/1/17:12:04:08 cwimmer WS-CWIM Installing Microsoft Visual C++ 2008 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\x86\VCRedist\2008SP1ATL\vcredist_x86_2008.exe /q 2013/1/17:12:04:11 cwimmer WS-CWIM Install Microsoft Visual C++ 2008 SP1 Redistributable ATL Security Update (x86) Succeeded 2013/1/17:12:04:11 cwimmer WS-CWIM Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:04:23 cwimmer WS-CWIM Install Autodesk Material Library 2012 Succeeded 2013/1/17:12:04:24 cwimmer WS-CWIM Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:04:43 cwimmer WS-CWIM Install Autodesk Material Library 2012 - Low Resolution Succeeded 2013/1/17:12:04:43 cwimmer WS-CWIM Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\cwimmer\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/17:12:04:46 cwimmer WS-CWIM Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2013/1/17:12:04:46 cwimmer WS-CWIM Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:04:54 cwimmer WS-CWIM Install Autodesk Content Service Succeeded 2013/1/17:12:04:54 cwimmer WS-CWIM Installing SQL Server CE 3.5 x86: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:04:57 cwimmer WS-CWIM Install SQL Server CE 3.5 x86 Succeeded 2013/1/17:12:04:57 cwimmer WS-CWIM Installing SQL Server CE 3.5 x64: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:05:01 cwimmer WS-CWIM Install SQL Server CE 3.5 x64 Succeeded 2013/1/17:12:05:01 cwimmer WS-CWIM Installing Microsoft Visual Basic Power Packs 3.0: C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\VBPowerPacks\VisualBasicPowerPacks3Setup.exe /q /l C:\Users\cwimmer\AppData\Local\Temp\VisualBasicPowerPacks3Setup.log 2013/1/17:12:05:05 cwimmer WS-CWIM Install Microsoft Visual Basic Power Packs 3.0 Succeeded 2013/1/17:12:05:05 cwimmer WS-CWIM Installing AutoCAD® Civil 3D® 2012: TRANSFORMS="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\x64\de-de\C3D\C3D.mst;C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\x64\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:10:40 cwimmer WS-CWIM Install AutoCAD® Civil 3D® 2012 Succeeded 2013/1/17:12:10:41 cwimmer WS-CWIM Installing AutoCAD® Civil 3D® 2012 Language Pack: TRANSFORMS="C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\_laB23A.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:16:06 cwimmer WS-CWIM Install AutoCAD® Civil 3D® 2012 Language Pack Succeeded 2013/1/17:12:16:06 cwimmer WS-CWIM Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\cwimmer\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/1/17:12:16:12 cwimmer WS-CWIM Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2013/1/17:12:16:12 cwimmer WS-CWIM Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\cwimmer\AppData\Local\Temp\vcredist_x64_2005.log"" " 2013/1/17:12:16:16 cwimmer WS-CWIM Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded 2013/1/17:12:16:17 cwimmer WS-CWIM Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:16:51 cwimmer WS-CWIM Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded 2013/1/17:12:16:51 cwimmer WS-CWIM Installing Autodesk® Backburner 2012: C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\x86\Components\backburner\BackburnerCIF.exe 2013/1/17:12:16:55 cwimmer WS-CWIM Install Autodesk® Backburner 2012 Succeeded 2013/1/17:12:16:55 cwimmer WS-CWIM Installing Autodesk® 3ds Max® Design 2012: TRANSFORMS="C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\x64\max\3dsMaxDesign2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max Design 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:18:49 cwimmer WS-CWIM Install Autodesk® 3ds Max® Design 2012 Succeeded 2013/1/17:12:18:49 cwimmer WS-CWIM Installing 3dsMax Composite 2012: INSTALLDIR="C:\Program Files\Autodesk\Composite 2012\" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:19:48 cwimmer WS-CWIM Install 3dsMax Composite 2012 Succeeded 2013/1/17:12:19:50 cwimmer WS-CWIM Installing AutoCAD® Map 3D 2012: TRANSFORMS="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\x64\de-de\acadmap\acadmap.mst;C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\x64\acadmap\acadmap-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Map 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:24:59 cwimmer WS-CWIM Install AutoCAD® Map 3D 2012 Succeeded 2013/1/17:12:25:00 cwimmer WS-CWIM Installing AutoCAD® Map 3D 2012 Language Pack: TRANSFORMS="C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\_laD143.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Map 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:29:42 cwimmer WS-CWIM Install AutoCAD® Map 3D 2012 Language Pack Succeeded 2013/1/17:12:29:42 cwimmer WS-CWIM Installing Microsoft Visual C++ 2008 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\x64\VCRedist\2008SP1ATL\vcredist_x64_2008.exe /q 2013/1/17:12:29:45 cwimmer WS-CWIM Install Microsoft Visual C++ 2008 SP1 Redistributable ATL Security Update (x64) Succeeded 2013/1/17:12:29:45 cwimmer WS-CWIM Installing Autodesk® Navisworks® Simulate 2012: TRANSFORMS="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\x64\de-de\NAVSIM\roamer.mst;C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\x64\NAVSIM\roamer-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Simulate 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:32:29 cwimmer WS-CWIM Install Autodesk® Navisworks® Simulate 2012 Succeeded 2013/1/17:12:32:29 cwimmer WS-CWIM Installing Autodesk® Navisworks® Simulate 2012 Language Pack: TRANSFORMS="C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\_laAB5E.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Simulate 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:32:38 cwimmer WS-CWIM Install Autodesk® Navisworks® Simulate 2012 Language Pack Succeeded 2013/1/17:12:32:38 cwimmer WS-CWIM Installing Navisworks® Simulate 2012 - 2012 DWG File Reader: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:33:03 cwimmer WS-CWIM Install Navisworks® Simulate 2012 - 2012 DWG File Reader Succeeded 2013/1/17:12:33:03 cwimmer WS-CWIM Installing Navisworks® Simulate 2012 - 2011 DWG File Reader: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:33:25 cwimmer WS-CWIM Install Navisworks® Simulate 2012 - 2011 DWG File Reader Succeeded 2013/1/17:12:33:26 cwimmer WS-CWIM Installing Navisworks® Simulate 2012 - 2010 DWG File Reader: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:33:45 cwimmer WS-CWIM Install Navisworks® Simulate 2012 - 2010 DWG File Reader Succeeded 2013/1/17:12:33:45 cwimmer WS-CWIM Installing Navisworks® Simulate 2012 - 2009 DWG File Reader: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:33:56 cwimmer WS-CWIM Install Navisworks® Simulate 2012 - 2009 DWG File Reader Succeeded 2013/1/17:12:33:56 cwimmer WS-CWIM Installing Navisworks® Simulate 2012 - 2008 DWG File Reader: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:34:07 cwimmer WS-CWIM Install Navisworks® Simulate 2012 - 2008 DWG File Reader Succeeded 2013/1/17:12:34:08 cwimmer WS-CWIM Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\x64\de-de\acad\acad.mst;C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - Deutsch\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:37:16 cwimmer WS-CWIM Install AutoCAD® 2012 Succeeded 2013/1/17:12:37:16 cwimmer WS-CWIM Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\cwimmer\AppData\Local\Temp\_AI7703.tmp\_laE08.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - Deutsch\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/17:12:39:43 cwimmer WS-CWIM Install AutoCAD® 2012 Language Pack Succeeded 2013/1/17:12:39:43 cwimmer WS-CWIM Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Infrastructure_Design_Suite_Premium_2012_German_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\cwimmer\AppData\Local\Temp\vcredist_x86_2010.log 2013/1/17:12:39:46 cwimmer WS-CWIM Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603 2013/1/17:12:39:58 cwimmer WS-CWIM Rollback AutoCAD® 2012 Language Pack Succeeded 2013/1/17:12:40:24 cwimmer WS-CWIM Rollback AutoCAD® 2012 Succeeded 2013/1/17:12:40:28 cwimmer WS-CWIM Rollback Navisworks® Simulate 2012 - 2008 DWG File Reader Succeeded 2013/1/17:12:40:32 cwimmer WS-CWIM Rollback Navisworks® Simulate 2012 - 2009 DWG File Reader Succeeded 2013/1/17:12:40:35 cwimmer WS-CWIM Rollback Navisworks® Simulate 2012 - 2010 DWG File Reader Succeeded 2013/1/17:12:40:38 cwimmer WS-CWIM Rollback Navisworks® Simulate 2012 - 2011 DWG File Reader Succeeded 2013/1/17:12:40:42 cwimmer WS-CWIM Rollback Navisworks® Simulate 2012 - 2012 DWG File Reader Succeeded 2013/1/17:12:40:46 cwimmer WS-CWIM Rollback Autodesk® Navisworks® Simulate 2012 Language Pack Succeeded 2013/1/17:12:42:03 cwimmer WS-CWIM Rollback Autodesk® Navisworks® Simulate 2012 Succeeded 2013/1/17:12:42:03 cwimmer WS-CWIM Rollback Microsoft Visual C++ 2008 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619 2013/1/17:12:42:30 cwimmer WS-CWIM Rollback AutoCAD® Map 3D 2012 Language Pack Succeeded 2013/1/17:12:43:40 cwimmer WS-CWIM Rollback AutoCAD® Map 3D 2012 Succeeded Reboot is required 2013/1/17:12:44:43 cwimmer WS-CWIM Rollback 3dsMax Composite 2012 Succeeded 2013/1/17:12:45:59 cwimmer WS-CWIM Rollback Autodesk® 3ds Max® Design 2012 Succeeded 2013/1/17:12:45:59 cwimmer WS-CWIM Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619 2013/1/17:12:46:29 cwimmer WS-CWIM Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded 2013/1/17:12:46:29 cwimmer WS-CWIM Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619 2013/1/17:12:46:29 cwimmer WS-CWIM Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2013/1/17:12:47:23 cwimmer WS-CWIM Rollback AutoCAD® Civil 3D® 2012 Language Pack Succeeded 2013/1/17:12:48:43 cwimmer WS-CWIM Rollback AutoCAD® Civil 3D® 2012 Succeeded Reboot is required 2013/1/17:12:48:43 cwimmer WS-CWIM Rollback Microsoft Visual Basic Power Packs 3.0 Failed Failure is ignored, Result=1619 2013/1/17:12:48:45 cwimmer WS-CWIM Rollback SQL Server CE 3.5 x64 Succeeded 2013/1/17:12:48:55 cwimmer WS-CWIM Rollback SQL Server CE 3.5 x86 Succeeded 2013/1/17:12:49:02 cwimmer WS-CWIM Rollback Autodesk Content Service Succeeded 2013/1/17:12:49:02 cwimmer WS-CWIM Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2013/1/17:12:49:12 cwimmer WS-CWIM Rollback Autodesk Material Library 2012 - Low Resolution Succeeded 2013/1/17:12:49:27 cwimmer WS-CWIM Rollback Autodesk Material Library 2012 Succeeded 2013/1/17:12:49:27 cwimmer WS-CWIM Rollback Microsoft Visual C++ 2008 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619 2013/1/17:12:49:27 cwimmer WS-CWIM Rollback FaroSDK Succeeded 2013/1/17:12:49:28 cwimmer WS-CWIM Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/1/17:12:49:28 cwimmer WS-CWIM Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
can anybody help me? THX
Solved by TravisNave. Go to Solution.
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
