Installation & Licensing
Active Member
gbr294
Message 1 of 3 (1,911 Views)
Installation complete. Some products failed to install
1911 Views, 2 Replies
01-24-2013 08:18 PM
Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618
Rollback FaroSDK Failed Failure is ignored, Result=1618
Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
This is the error I'm receiving when trying to install Revit 2013. Someone please help me because I need this for school. Thanks.
TravisNave
Message 2 of 3 (1,887 Views)
Re: Installation complete. Some products failed to install
01-25-2013 07:31 AM in reply to: gbr294
1618 means that the MSI Installer thinks another installation is already in progress.  Did you start an install and then cancel it?  Have you tried rebooting?
Active Member
gbr294
Message 3 of 3 (1,842 Views)
01-27-2013 06:48 PM in reply to: TravisNave
I did cancel it because it was taking so long...but I later realized that I didn't have enough disk space. So, I cleaned the disk space and I restarted my PC. I tried to install Revit 13 again and now I'm receiving this error:
Install Autodesk Revit 2013  Failed Download Failed, Installation aborted, Result=1603
Rollback FaroSDK                Failed Failure is ignored, Result=1619
Rollback DirectX Runtime     Failed Failure is ignored, Result=1619
