Installation & Licensing
Installation complete. Some products failed to install. Please help :/
2 REPLIES 2
bodiroga89
1068 Views, 2 Replies
I tried to uninstall c ++, and .NET also but still get this message. Please help. Thank you. Here is the log:
2013/2/28:10:15:35    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:15:35    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:16:14    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:15:39    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:15:39    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:16:14    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:10:16:42    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:10:16:58    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:10:23:08    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:10:23:52    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:10:23:52    Dejan#4    DEJAN4-PC    Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:10:26:29    Dejan#4    DEJAN4-PC    Install    .NET Framework Runtime 4.0    Succeeded
2013/2/28:10:26:29    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:26:53    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:10:26:53    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:10:27:04    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:10:27:05    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI65F3.tmp\Media.mst"
 2013/2/28:10:27:21    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:10:27:23    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI65F3.tmp\Media.mst"
 2013/2/28:10:27:45    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:27:45    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:27:47    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:10:27:58    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:28:08    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:10:28:11    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:10:28:11    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:10:28:11    Dejan#4    DEJAN4-PC    Rollback    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1619
2013/2/28:10:28:11    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:10:28:35    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:30:25    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:30:25    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:30:30    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:30:26    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:30:26    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:30:29    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:10:30:45    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:10:31:04    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:10:32:07    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:10:32:42    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:10:32:42    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:32:59    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:10:32:59    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:10:33:07    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:10:33:08    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIF077.tmp\Media.mst"
 2013/2/28:10:33:18    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:10:33:21    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIF077.tmp\Media.mst"
 2013/2/28:10:33:41    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:33:41    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:33:41    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:10:33:56    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:34:07    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:10:34:09    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:10:34:09    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:10:34:09    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:10:41:27    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:42:01    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:42:01    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:42:07    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:42:06    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:10:42:13    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:10:42:19    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:10:42:45    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:10:42:56    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:10:42:56    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:43:14    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:10:43:14    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:10:43:22    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:10:43:23    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI9B07.tmp\Media.mst"
 2013/2/28:10:43:33    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:10:43:33    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI9B07.tmp\Media.mst"
 2013/2/28:10:43:55    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:43:55    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:43:55    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:10:44:08    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:44:18    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:10:44:20    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:10:44:20    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:10:44:20    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:10:44:43    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:02:45    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:02:45    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:03:29    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:02:50    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:02:50    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:03:29    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:03:38    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:03:49    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:04:19    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:04:23    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:04:23    Dejan#4    DEJAN4-PC    Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:11:05:45    Dejan#4    DEJAN4-PC    Install    .NET Framework Runtime 4.0    Succeeded
2013/2/28:11:05:45    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:06:14    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:06:14    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:06:23    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:06:23    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI41C0.tmp\Media.mst"
 2013/2/28:11:06:38    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:06:38    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI41C0.tmp\Media.mst"
 2013/2/28:11:07:02    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:07:02    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:07:03    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:07:17    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:07:28    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:07:31    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:07:31    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:07:31    Dejan#4    DEJAN4-PC    Rollback    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1619
2013/2/28:11:07:32    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:15:50    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:16:28    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:16:28    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:16:34    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:16:29    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:16:29    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:16:34    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:16:41    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:16:47    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:17:12    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:17:15    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:17:16    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:17:34    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:17:34    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:17:47    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:17:48    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AID21D.tmp\Media.mst"
 2013/2/28:11:17:59    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:18:03    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AID21D.tmp\Media.mst"
 2013/2/28:11:18:24    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:18:24    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:18:24    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:18:40    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:18:51    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:18:53    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:18:53    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:18:53    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:23:00    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:23:22    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:23:22    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:23:28    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:23:23    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:23:23    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:23:28    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:23:35    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:23:40    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:24:00    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:24:07    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:24:07    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:24:25    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:24:25    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:24:33    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:24:34    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI2480.tmp\Media.mst"
 2013/2/28:11:24:44    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:24:47    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI2480.tmp\Media.mst"
 2013/2/28:11:25:07    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:25:07    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:25:08    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:25:22    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:25:33    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:25:35    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:25:35    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:25:35    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:25:43    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:28:27    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:28:27    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:28:33    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:28:28    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:28:28    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:28:33    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:28:43    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:28:47    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:28:57    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:28:59    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:28:59    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:29:18    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:29:18    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:29:26    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:29:28    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AICB5A.tmp\Media.mst"
 2013/2/28:11:29:38    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:29:40    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AICB5A.tmp\Media.mst"
 2013/2/28:11:30:02    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:30:02    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:30:02    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:30:15    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:30:25    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:30:27    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:30:27    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:30:27    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:33:22    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:33:28    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:33:28    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:33:34    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:33:29    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:33:29    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:33:34    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:33:40    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:33:45    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:33:53    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:33:55    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:33:55    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/28:11:34:08    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2013/2/28:11:34:08    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:34:27    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:34:27    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:34:35    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:34:36    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI5C43.tmp\Media.mst"
 2013/2/28:11:34:48    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:34:51    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI5C43.tmp\Media.mst"
 2013/2/28:11:35:12    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:35:12    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:35:13    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:35:27    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:35:39    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:35:41    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:35:41    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:35:41    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:35:59    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:41:29    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:41:29    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:41:37    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:41:30    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:41:30    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:41:35    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:41:39    Dejan#4    DEJAN4-PC    You are attempting to use a 64-bit installer on a 32-bit operating system.
Please exit and use the 32-bit installer available from your installation media or from Autodesk.com.2013/2/28:11:41:50    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:54:30    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:54:30    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:55:23    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:54:36    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:54:36    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:55:23    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:55:33    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:55:44    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:56:06    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:56:27    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:56:39    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:56:56    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:56:56    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:57:22    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:57:22    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:57:37    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:57:37    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIA332.tmp\Media.mst"
 2013/2/28:11:57:54    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:57:56    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIA332.tmp\Media.mst"
 2013/2/28:11:58:16    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:58:16    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:58:18    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:58:30    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:58:40    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:58:42    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:58:42    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:12:08:19    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:12:08:19    Dejan#4    DEJAN4-PC    Launch
2013/2/28:12:09:04    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:12:08:24    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:12:08:24    Dejan#4    DEJAN4-PC    Launch
2013/2/28:12:09:04    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:12:09:34    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:12:09:39    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:12:09:52    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:12:09:56    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:12:09:57    Dejan#4    DEJAN4-PC    Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:12:13:06    Dejan#4    DEJAN4-PC    Install    .NET Framework Runtime 4.0    Succeeded
2013/2/28:12:13:06    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/28:12:13:24    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2013/2/28:12:13:24    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:12:13:53    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:12:13:53    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:12:14:05    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:12:14:06    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIDFA4.tmp\Media.mst"
 2013/2/28:12:14:24    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:12:14:26    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIDFA4.tmp\Media.mst"
 2013/2/28:12:14:50    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:12:14:50    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:12:14:53    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:12:15:06    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:12:15:18    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:12:15:20    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:12:15:20    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:12:15:20    Dejan#4    DEJAN4-PC    Rollback    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1619
2 REPLIES 2
david.lau
in reply to: bodiroga89
TravisNave
If uninstalling the offending program and reinstalling does not solve the problem, then install the prereq direct from Microsoft and then edit the setup.ini to ignore the prerequisite check.  I have instructions on my follow-up post at this link:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
