I tried to uninstall c ++, and .NET also but still get this message. Please help. Thank you. Here is the log:
2013/2/28:10:15:35 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:15:35 Dejan#4 DEJAN4-PC Launch
2013/2/28:10:16:14 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:10:15:39 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:15:39 Dejan#4 DEJAN4-PC Launch
2013/2/28:10:16:14 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:10:16:42 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:10:16:58 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:10:23:08 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:10:23:52 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:10:23:52 Dejan#4 DEJAN4-PC Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:10:26:29 Dejan#4 DEJAN4-PC Install .NET Framework Runtime 4.0 Succeeded
2013/2/28:10:26:29 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:26:53 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:10:26:53 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:10:27:04 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:10:27:05 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI65F3.tmp\Media.mst"
2013/2/28:10:27:21 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:10:27:23 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI65F3.tmp\Media.mst"
2013/2/28:10:27:45 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:10:27:45 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:27:47 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:10:27:58 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:10:28:08 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:10:28:11 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:10:28:11 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:10:28:11 Dejan#4 DEJAN4-PC Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
2013/2/28:10:28:11 Dejan#4 DEJAN4-PC PageOpen InstallCompleteDialog
2013/2/28:10:28:35 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:10:30:25 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:30:25 Dejan#4 DEJAN4-PC Launch
2013/2/28:10:30:30 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:10:30:26 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:30:26 Dejan#4 DEJAN4-PC Launch
2013/2/28:10:30:29 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:10:30:45 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:10:31:04 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:10:32:07 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:10:32:42 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:10:32:42 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:32:59 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:10:32:59 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:10:33:07 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:10:33:08 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIF077.tmp\Media.mst"
2013/2/28:10:33:18 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:10:33:21 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIF077.tmp\Media.mst"
2013/2/28:10:33:41 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:10:33:41 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:33:41 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:10:33:56 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:10:34:07 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:10:34:09 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:10:34:09 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:10:34:09 Dejan#4 DEJAN4-PC PageOpen InstallCompleteDialog
2013/2/28:10:41:27 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:10:42:01 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:42:01 Dejan#4 DEJAN4-PC Launch
2013/2/28:10:42:07 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:10:42:06 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:10:42:13 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:10:42:19 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:10:42:45 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:10:42:56 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:10:42:56 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:43:14 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:10:43:14 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:10:43:22 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:10:43:23 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI9B07.tmp\Media.mst"
2013/2/28:10:43:33 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:10:43:33 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI9B07.tmp\Media.mst"
2013/2/28:10:43:55 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:10:43:55 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:43:55 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:10:44:08 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:10:44:18 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:10:44:20 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:10:44:20 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:10:44:20 Dejan#4 DEJAN4-PC PageOpen InstallCompleteDialog
2013/2/28:10:44:43 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:02:45 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:02:45 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:03:29 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:02:50 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:02:50 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:03:29 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:11:03:38 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:11:03:49 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:11:04:19 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:11:04:23 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:11:04:23 Dejan#4 DEJAN4-PC Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:11:05:45 Dejan#4 DEJAN4-PC Install .NET Framework Runtime 4.0 Succeeded
2013/2/28:11:05:45 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:06:14 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:11:06:14 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:11:06:23 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:11:06:23 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI41C0.tmp\Media.mst"
2013/2/28:11:06:38 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:11:06:38 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI41C0.tmp\Media.mst"
2013/2/28:11:07:02 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:07:02 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:07:03 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:11:07:17 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:07:28 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:11:07:31 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:11:07:31 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:11:07:31 Dejan#4 DEJAN4-PC Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
2013/2/28:11:07:32 Dejan#4 DEJAN4-PC PageOpen InstallCompleteDialog
2013/2/28:11:15:50 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:16:28 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:16:28 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:16:34 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:16:29 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:16:29 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:16:34 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:11:16:41 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:11:16:47 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:11:17:12 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:11:17:15 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:11:17:16 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:17:34 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:11:17:34 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:11:17:47 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:11:17:48 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AID21D.tmp\Media.mst"
2013/2/28:11:17:59 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:11:18:03 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AID21D.tmp\Media.mst"
2013/2/28:11:18:24 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:18:24 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:18:24 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:11:18:40 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:18:51 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:11:18:53 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:11:18:53 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:11:18:53 Dejan#4 DEJAN4-PC PageOpen InstallCompleteDialog
2013/2/28:11:23:00 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:23:22 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:23:22 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:23:28 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:23:23 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:23:23 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:23:28 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:11:23:35 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:11:23:40 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:11:24:00 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:11:24:07 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:11:24:07 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:24:25 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:11:24:25 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:11:24:33 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:11:24:34 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI2480.tmp\Media.mst"
2013/2/28:11:24:44 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:11:24:47 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI2480.tmp\Media.mst"
2013/2/28:11:25:07 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:25:07 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:25:08 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:11:25:22 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:25:33 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:11:25:35 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:11:25:35 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:11:25:35 Dejan#4 DEJAN4-PC PageOpen InstallCompleteDialog
2013/2/28:11:25:43 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:28:27 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:28:27 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:28:33 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:28:28 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:28:28 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:28:33 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:11:28:43 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:11:28:47 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:11:28:57 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:11:28:59 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:11:28:59 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:29:18 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:11:29:18 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:11:29:26 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:11:29:28 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AICB5A.tmp\Media.mst"
2013/2/28:11:29:38 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:11:29:40 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AICB5A.tmp\Media.mst"
2013/2/28:11:30:02 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:30:02 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:30:02 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:11:30:15 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:30:25 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:11:30:27 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:11:30:27 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:11:30:27 Dejan#4 DEJAN4-PC PageOpen InstallCompleteDialog
2013/2/28:11:33:22 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:33:28 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:33:28 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:33:34 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:33:29 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:33:29 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:33:34 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:11:33:40 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:11:33:45 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:11:33:53 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:11:33:55 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:11:33:55 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/28:11:34:08 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/28:11:34:08 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:34:27 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:11:34:27 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:11:34:35 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:11:34:36 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI5C43.tmp\Media.mst"
2013/2/28:11:34:48 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:11:34:51 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI5C43.tmp\Media.mst"
2013/2/28:11:35:12 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:35:12 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:35:13 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:11:35:27 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:35:39 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:11:35:41 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:11:35:41 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:11:35:41 Dejan#4 DEJAN4-PC PageOpen InstallCompleteDialog
2013/2/28:11:35:59 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:41:29 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:41:29 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:41:37 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:41:30 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:41:30 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:41:35 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:11:41:39 Dejan#4 DEJAN4-PC You are attempting to use a 64-bit installer on a 32-bit operating system.
Please exit and use the 32-bit installer available from your installation media or from Autodesk.com.2013/2/28:11:41:50 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:54:30 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:54:30 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:55:23 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:11:54:36 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:54:36 Dejan#4 DEJAN4-PC Launch
2013/2/28:11:55:23 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:11:55:33 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:11:55:44 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:11:56:06 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:11:56:27 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:11:56:39 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:11:56:56 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:11:56:56 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:57:22 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:11:57:22 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:11:57:37 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:11:57:37 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIA332.tmp\Media.mst"
2013/2/28:11:57:54 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:11:57:56 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIA332.tmp\Media.mst"
2013/2/28:11:58:16 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:58:16 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:58:18 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:11:58:30 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:11:58:40 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:11:58:42 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:11:58:42 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:12:08:19 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:12:08:19 Dejan#4 DEJAN4-PC Launch
2013/2/28:12:09:04 Dejan#4 DEJAN4-PC === Setup ended ===
2013/2/28:12:08:24 Dejan#4 DEJAN4-PC === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:12:08:24 Dejan#4 DEJAN4-PC Launch
2013/2/28:12:09:04 Dejan#4 DEJAN4-PC PageOpen LaunchDialog
2013/2/28:12:09:34 Dejan#4 DEJAN4-PC PageOpen LicenseDialog
2013/2/28:12:09:39 Dejan#4 DEJAN4-PC PageOpen ProductInfoDialog
2013/2/28:12:09:52 Dejan#4 DEJAN4-PC PageOpen ProductSelectionDialog2
2013/2/28:12:09:56 Dejan#4 DEJAN4-PC PageOpen FullProgressDialog
2013/2/28:12:09:57 Dejan#4 DEJAN4-PC Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:12:13:06 Dejan#4 DEJAN4-PC Install .NET Framework Runtime 4.0 Succeeded
2013/2/28:12:13:06 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/28:12:13:24 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/28:12:13:24 Dejan#4 DEJAN4-PC Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:12:13:53 Dejan#4 DEJAN4-PC Install DirectX Runtime Succeeded
2013/2/28:12:13:53 Dejan#4 DEJAN4-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/28:12:14:05 Dejan#4 DEJAN4-PC Install FaroSDK Succeeded
2013/2/28:12:14:06 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIDFA4.tmp\Media.mst"
2013/2/28:12:14:24 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 Succeeded
2013/2/28:12:14:26 Dejan#4 DEJAN4-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIDFA4.tmp\Media.mst"
2013/2/28:12:14:50 Dejan#4 DEJAN4-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:12:14:50 Dejan#4 DEJAN4-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:12:14:53 Dejan#4 DEJAN4-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/2/28:12:15:06 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/2/28:12:15:18 Dejan#4 DEJAN4-PC Rollback Autodesk Material Library 2012 Succeeded
2013/2/28:12:15:20 Dejan#4 DEJAN4-PC Rollback FaroSDK Succeeded
2013/2/28:12:15:20 Dejan#4 DEJAN4-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/2/28:12:15:20 Dejan#4 DEJAN4-PC Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
If uninstalling the offending program and reinstalling does not solve the problem, then install the prereq direct from Microsoft and then edit the setup.ini to ignore the prerequisite check. I have instructions on my follow-up post at this link:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
