Installation & Licensing
installation complete.some products failed to install + logfile
5 REPLIES 5
6564 Views, 5 Replies
Cannot install inventor 2012
enabled virus scanner
Naam van besturingssysteem    Microsoft Windows 7 Professional
Versie    6.1.7601 Service Pack 1 Build 7601
Andere beschrijving van besturingssysteem    Niet beschikbaar
Leverancier van besturingssysteem    Microsoft Corporation
Systeemnaam    SABERTOOTH
Systeemfabrikant     System manufacturer
Systeemmodel    System Product Name
Systeemtype    Op x64-gebaseerde PC
Processor    Intel(R) Core(TM) i7 CPU         960  @ 3.20GHz, 3201 MHz, 4 core('s), 8 logische processor(s)
BIOS-versie/datum    American Megatrends Inc. 1101, 11/05/2011
SMBIOS-versie    2.5
Map met Windows    C:\Windows
Systeemmap    C:\Windows\system32
Opstartapparaat    \Device\HarddiskVolume3
Landinstelling    België
HAL (Hardware Abstraction Layer)    Versie = "6.1.7601.17514"
Gebruikersnaam    Sabertooth\Curd
Tijdzone    Romance (standaardtijd)
Geïnstalleerd fysiek geheugen (RAM)    12,0 GB
Totaal fysiek geheugen    12,0 GB
Beschikbaar fysiek geheugen    9,95 GB
Totaal virtueel geheugen    24,0 GB
Beschikbaar virtueel geheugen    21,7 GB
Ruimte voor wisselbestand    12,0 GB
Wisselbestand    C:\pagefile.sys
grtz from belgium.curd
5 REPLIES 5
TravisNave
You might already have a newer version of Microsoft Visual C++ 2010 Redistributable (x86) installed.  Use the Control Panel > Programs and Features to remove this version.  Reboot, then reinstall your Autodesk product.  It should install the version supplied and continue the installation.  If not, consider installing the Microsoft Visual C++ 2010 Redistributable (x86) directly from Microsoft.com.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
removed it , works fine now.
tyvm curd
The installation log file is attached with this mail which i got after incomplete installation of Autodesk Inventor12.
someone please try to solve my problem , i tried many time to install this software but got same message
TravisNave
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
in reply to: TravisNave
Its ok tyvm curd.
Administrator Productivity
