Hello, im trying to install AC 2012 LT on virtual machine (Windows Server 2008R2 x64) and im getting "incorrect function" error message as attached screen shot shows, any ideas how to deal with that ?
AutoCAD is not supported to be installed on a Server OS. Is your VM a workstation class operating system or is the entire VM a server?
You'll want to install it on a workstation OS like Windows 7.
well i would like to use some features from Win Srv but your answer make things clear about such possibility so thanks for the support Travis:)
Agreed. However, Autodesk doesn't support server operating systems generally because they do not want you to use terminal services or other remote access features of server to access the license. They are pretty strict in their license terms.
