Installation & Licensing
Installation asks for disc, but I downloaded it from internet.
2 REPLIES 2
ShawnEO
324 Views, 2 Replies
I downloaded Autodesk Map 3D from the site to an SD card on one computer using "Download Now", and inserted to card into the computer I wanted to install it on and began the installation.  Midway through, the installation stopped and said I needed to insert Disc 11.  Obviously, since I downloaded it I don't have any discs.  My only options were to insert the non-existant disc or to cancel installation.  I have a student account and cannot get any discs.
What do I need to do?
2 REPLIES 2
TravisNave
in reply to: ShawnEO
Copy the contents of the SD to the local hard drive.  Because the SD is removable media, it thinks it needs a disc change.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dembkod
ShawnEO
Hello. Copying the files over will likely work. I am guessing there was a pathing problem with the download. You could also to a “Browser Downlaod” and use those files. They are easily moveable.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
