I have tried several times to "Install Now" and "Download Now" the Student Version of Revit Arch 2011 only because our college has not upgraded Yet.
Under the 3 catagoriies that are asked for: version 2011,Language English, and Windows. How do I tell it that I have a 64-BIT when revit does not give me a pull down for the proper information. Under download tells me to go to control panel and turn on 64-bit on my computor and I cant find where that would be. Please Help
Regards, Tom A.
Hi Tomas and welcome to the Community.
If you are having issues or difficulties with either Install Now or Download Now methods, you may try using the Browser Download method to download the installer for Autodesk Revit Architecture 2011.
With regard to the version and categories, if the operating system does not differentiate the 32-bit and 64-bit and only shows Windows, this usually means that the installer is applicable for either or both Windows 32-bit and Windows 64-bit OS. On the other hand, if you wish to determine if you have a 32-bit or a 64-bit Windows OS, you can check this out: 32-Bit or 64-Bit
@Anonymous wrote:
Hi Jeffrey,Thank you for your quick response, I was able to install, but the progress ended with a pop-up message of a corrupt file of Revit and to clean up and reinstall.Message at the end of its progress said:CRC failed in RevitSetup\RevitArchitecture\x86.cabUnexpected end of archive.
you can't fix these
this is just a corrupt download all you can do is try to redownload again
turn off firewall and any antivirus software
DarrenP
