Problem: When installing your Autodesk product, your installation fails and the resulting installation.log file on the summary screen (and your %TEMP% folder) shows the following error:
Install .NET Framework Runtime Language Pack Failed Installation aborted, Result=1603
Reason: It is possible that the .NET Framework preinstalled in some Windows 7 and Windows 8 machines is not the full installation and the update for the language pack cannot install if a previous version or newer version is already installed. This is a very similar issue in the past with the Prerequisite 1603 failures for .NET Framework and Visual C++ Redistributables failing. This guide acts as a supplement to that article.
Note: There is not an English version of the Language pack for this program. More information about this can be found at the following Microsoft resource:
http://www.microsoft.com/en-us/download/details.aspx?id=3324
Work Around: To best avoid this error on newer Autodesk installations, it is best if you first install the prerequisite first and then modify the setup.ini file in the installation source to ignore the failure of the language pack install.
Step 1: Copy the contents of your install media to your local hard drive. If you have the downloaded version, then you already have completed this step.
Step 2: Locate the file in the root source folder named Setup.ini and make a backup of this file. Open the file in Notepad for editing.
Step 3: Perform a search to find the [DOTNET4LANG] located in this file. Later versions may have newer language file prerequisites, such as [DOTNET45LANG], etc.
Step 4: Add the following line to the prerequisite grouping under the existing EXE_ settings:
IGNORE_FAILURE=YES
Your resulting Prereq should look similar to this:
[DOTNET4LANG] PRODUCT_NAME=.NET Framework Runtime 4.0 Language Pack EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_%lang%.exe EXE_PARAM=/q EXE_LANGS=1036;1040;1031;1034;1046;1041;1042;2052;1028;1029;1038;1045;1049 IGNORE_FAILURE=YES
DISKCOST=3000000 VC_FUNC=DotnetLangPacksVerCheck VC_SOURCE=Setup\SetupUi.dll VC_PARAM=%lang%;4.0.30319
Step 5: Save the file and run the installer.
As always, make sure that you are installing with local Administrator Rights, UAC turned off, and anti-virus temporarily disabled.
Attached is a copy of the Autodesk AutoCAD 2014 (vanilla) setup.ini file that I have modified for this example. Use this file only as a reference and not as your file.
Solved by TravisNave. Go to Solution.
I GOT ERROR ALOT TIME WHEN IM INSTALLING REVIT MEP 2014
Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86 FaiL Installation aborted, Result=1603
2016/1/28:14:26:47 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/1/28:14:26:47 user WS_MF_0011 Path_Length: 149
2016/1/28:14:26:47 user WS_MF_0011 Current Directory D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm
2016/1/28:14:26:47 user WS_MF_0011 Launch
2016/1/28:14:26:47 user WS_MF_0011 CommandLine
2016/1/28:14:26:47 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI38CB.tmp
2016/1/28:14:27:11 user WS_MF_0011 === Setup ended ===
2016/1/28:14:26:52 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/1/28:14:26:52 user WS_MF_0011 Path_Length: 149
2016/1/28:14:26:52 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI38CB.tmp
2016/1/28:14:26:52 user WS_MF_0011 Launch
2016/1/28:14:26:55 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI38CB.tmp\Setup\RevitSetup.dll
2016/1/28:14:26:55 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/1/28:14:27:05 user WS_MF_0011 PageOpen LaunchDialog
2016/1/28:14:27:13 user WS_MF_0011 PageOpen LicenseDialog
2016/1/28:14:27:16 user WS_MF_0011 PageOpen ProductInfoDialog
2016/1/28:14:28:12 user WS_MF_0011 PageOpen ProductSelectionDialog2
2016/1/28:14:28:17 user WS_MF_0011 PageOpen FullProgressDialog
2016/1/28:14:28:17 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/1/28:14:28:21 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/1/28:14:28:21 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/1/28:14:28:36 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2016/1/28:14:28:36 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/28:14:28:37 user WS_MF_0011 PageOpen InstallCompleteDialog
2016/1/28:14:29:17 user WS_MF_0011 === Setup ended ===
2016/1/28:16:27:56 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/1/28:16:27:56 user WS_MF_0011 Path_Length: 149
2016/1/28:16:27:56 user WS_MF_0011 Current Directory D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm
2016/1/28:16:27:56 user WS_MF_0011 Launch
2016/1/28:16:27:56 user WS_MF_0011 CommandLine
2016/1/28:16:27:56 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI233B.tmp
2016/1/28:16:28:00 user WS_MF_0011 === Setup ended ===
2016/1/28:16:27:58 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/1/28:16:27:58 user WS_MF_0011 Path_Length: 149
2016/1/28:16:27:58 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI233B.tmp
2016/1/28:16:27:58 user WS_MF_0011 Launch
2016/1/28:16:27:58 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI233B.tmp\Setup\RevitSetup.dll
2016/1/28:16:27:58 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/1/28:16:28:00 user WS_MF_0011 PageOpen LaunchDialog
2016/1/28:16:28:01 user WS_MF_0011 PageOpen LicenseDialog
2016/1/28:16:28:03 user WS_MF_0011 PageOpen ProductInfoDialog
2016/1/28:16:28:10 user WS_MF_0011 PageOpen ProductSelectionDialog2
2016/1/28:16:28:12 user WS_MF_0011 PageOpen FullProgressDialog
2016/1/28:16:28:12 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/1/28:16:28:14 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/1/28:16:28:14 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/1/28:16:28:30 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2016/1/28:16:28:30 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/28:16:28:30 user WS_MF_0011 PageOpen InstallCompleteDialog
2016/1/28:16:28:32 user WS_MF_0011 === Setup ended ===
2016/1/28:16:30:41 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/1/28:16:30:41 user WS_MF_0011 Path_Length: 149
2016/1/28:16:30:41 user WS_MF_0011 Current Directory D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm
2016/1/28:16:30:41 user WS_MF_0011 Launch
2016/1/28:16:30:41 user WS_MF_0011 CommandLine
2016/1/28:16:30:41 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AIA507.tmp
2016/1/28:16:30:48 user WS_MF_0011 === Setup ended ===
2016/1/28:16:30:43 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/1/28:16:30:43 user WS_MF_0011 Path_Length: 149
2016/1/28:16:30:43 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AIA507.tmp
2016/1/28:16:30:43 user WS_MF_0011 Launch
2016/1/28:16:30:45 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIA507.tmp\Setup\RevitSetup.dll
2016/1/28:16:30:45 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/1/28:16:30:48 user WS_MF_0011 PageOpen LaunchDialog
2016/1/28:16:30:52 user WS_MF_0011 PageOpen LicenseDialog
2016/1/28:16:30:53 user WS_MF_0011 PageOpen ProductInfoDialog
2016/1/28:16:31:03 user WS_MF_0011 PageOpen ProductSelectionDialog2
2016/1/28:16:31:05 user WS_MF_0011 PageOpen FullProgressDialog
2016/1/28:16:31:05 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/1/28:16:31:08 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/1/28:16:31:08 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x64): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2016/1/28:16:31:12 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2016/1/28:16:31:12 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/1/28:16:31:28 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2016/1/28:16:31:28 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2016/1/28:16:31:28 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2016/1/28:16:31:28 user WS_MF_0011 PageOpen InstallCompleteDialog
2016/1/28:16:38:11 user WS_MF_0011 === Setup ended ===
2016/2/1:09:50:56 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/2/1:09:50:56 user WS_MF_0011 Path_Length: 149
2016/2/1:09:50:56 user WS_MF_0011 Current Directory D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm
2016/2/1:09:50:56 user WS_MF_0011 Launch
2016/2/1:09:50:56 user WS_MF_0011 CommandLine
2016/2/1:09:50:56 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AIBB4.tmp
2016/2/1:09:51:11 user WS_MF_0011 === Setup ended ===
2016/2/1:09:51:03 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/2/1:09:51:03 user WS_MF_0011 Path_Length: 149
2016/2/1:09:51:03 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AIBB4.tmp
2016/2/1:09:51:03 user WS_MF_0011 Launch
2016/2/1:09:51:05 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIBB4.tmp\Setup\RevitSetup.dll
2016/2/1:09:51:05 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/1:09:51:11 user WS_MF_0011 PageOpen LaunchDialog
2016/2/1:09:51:13 user WS_MF_0011 PageOpen LicenseDialog
2016/2/1:09:51:14 user WS_MF_0011 PageOpen ProductInfoDialog
2016/2/1:09:52:02 user WS_MF_0011 PageOpen ProductSelectionDialog2
2016/2/1:09:52:04 user WS_MF_0011 PageOpen FullProgressDialog
2016/2/1:09:52:04 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/2/1:09:52:07 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/2/1:09:52:07 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/2/1:09:52:20 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2016/2/1:09:52:20 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2016/2/1:09:52:20 user WS_MF_0011 PageOpen InstallCompleteDialog
2016/2/1:09:52:57 user WS_MF_0011 === Setup ended ===
2016/2/1:09:58:34 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/2/1:09:58:34 user WS_MF_0011 Path_Length: 149
2016/2/1:09:58:34 user WS_MF_0011 Current Directory D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm
2016/2/1:09:58:34 user WS_MF_0011 Launch
2016/2/1:09:58:34 user WS_MF_0011 CommandLine
2016/2/1:09:58:34 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI703.tmp
2016/2/1:09:58:37 user WS_MF_0011 === Setup ended ===
2016/2/1:09:58:35 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/2/1:09:58:35 user WS_MF_0011 Path_Length: 149
2016/2/1:09:58:35 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI703.tmp
2016/2/1:09:58:35 user WS_MF_0011 Launch
2016/2/1:09:58:35 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI703.tmp\Setup\RevitSetup.dll
2016/2/1:09:58:35 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/1:09:58:37 user WS_MF_0011 PageOpen LaunchDialog
2016/2/1:09:58:38 user WS_MF_0011 PageOpen LicenseDialog
2016/2/1:09:58:39 user WS_MF_0011 PageOpen ProductInfoDialog
2016/2/1:09:58:48 user WS_MF_0011 PageOpen ProductSelectionDialog2
2016/2/1:09:58:50 user WS_MF_0011 PageOpen FullProgressDialog
2016/2/1:09:58:50 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x64): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2016/2/1:09:58:54 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2016/2/1:09:58:54 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2014\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/2/1:09:59:07 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2016/2/1:09:59:07 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2016/2/1:09:59:07 user WS_MF_0011 PageOpen InstallCompleteDialog
2016/2/1:09:59:32 user WS_MF_0011 === Setup ended ===
2016/2/1:10:07:50 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/2/1:10:07:50 user WS_MF_0011 Path_Length: 149
2016/2/1:10:07:50 user WS_MF_0011 Current Directory C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm
2016/2/1:10:07:50 user WS_MF_0011 Launch
2016/2/1:10:07:50 user WS_MF_0011 CommandLine
2016/2/1:10:07:50 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI82A8.tmp
2016/2/1:10:07:55 user WS_MF_0011 === Setup ended ===
2016/2/1:10:07:51 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/2/1:10:07:51 user WS_MF_0011 Path_Length: 149
2016/2/1:10:07:51 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI82A8.tmp
2016/2/1:10:07:51 user WS_MF_0011 Launch
2016/2/1:10:07:52 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI82A8.tmp\Setup\RevitSetup.dll
2016/2/1:10:07:52 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/1:10:07:55 user WS_MF_0011 PageOpen LaunchDialog
2016/2/1:10:07:56 user WS_MF_0011 PageOpen LicenseDialog
2016/2/1:10:07:59 user WS_MF_0011 PageOpen ProductInfoDialog
2016/2/1:10:08:08 user WS_MF_0011 PageOpen ProductSelectionDialog2
2016/2/1:10:08:17 user WS_MF_0011 PageOpen FullProgressDialog
2016/2/1:10:08:17 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/2/1:10:08:19 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/2/1:10:08:19 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/2/1:10:08:33 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2016/2/1:10:08:33 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2016/2/1:10:08:33 user WS_MF_0011 PageOpen InstallCompleteDialog
2016/2/1:10:10:23 user WS_MF_0011 === Setup ended ===
2016/2/1:10:28:26 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/2/1:10:28:26 user WS_MF_0011 Path_Length: 149
2016/2/1:10:28:26 user WS_MF_0011 Current Directory C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm
2016/2/1:10:28:26 user WS_MF_0011 Launch
2016/2/1:10:28:26 user WS_MF_0011 CommandLine
2016/2/1:10:28:26 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI60B7.tmp
2016/2/1:10:28:29 user WS_MF_0011 === Setup ended ===
2016/2/1:10:28:28 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2016/2/1:10:28:28 user WS_MF_0011 Path_Length: 149
2016/2/1:10:28:28 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI60B7.tmp
2016/2/1:10:28:28 user WS_MF_0011 Launch
2016/2/1:10:28:28 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI60B7.tmp\Setup\RevitSetup.dll
2016/2/1:10:28:28 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/2/1:10:28:29 user WS_MF_0011 PageOpen LaunchDialog
2016/2/1:10:28:30 user WS_MF_0011 PageOpen LicenseDialog
2016/2/1:10:28:33 user WS_MF_0011 PageOpen ProductInfoDialog
2016/2/1:10:28:41 user WS_MF_0011 PageOpen ProductSelectionDialog2
2016/2/1:10:28:42 user WS_MF_0011 PageOpen FullProgressDialog
2016/2/1:10:28:42 user WS_MF_0011 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/2/1:10:28:52 user WS_MF_0011 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/2/1:10:28:52 user WS_MF_0011 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/2/1:10:28:58 user WS_MF_0011 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2016/2/1:10:28:58 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/2/1:10:29:02 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/2/1:10:29:02 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2016/2/1:10:29:06 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2016/2/1:10:29:06 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk_Revit_MEP_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/2/1:10:29:17 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2016/2/1:10:29:17 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2016/2/1:10:29:17 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
