I have a Microsoft Surface Pro with a limited hard-drive, so I'm trying to install Inventor to an attached SD card (or a USB flash drive if thats any better). When I go through setup and install, I cannot select the SD card for install, even though I can see it as an option. Is there a way to install directly to an SD card to run Inventor from?
**I am a student, and am downlaoding the student version. Not sure if this makes a difference.
Solved by TravisNave. Go to Solution.
i wouldn't recommend it
it will be to slow and the sd card would have to be always be plugged into the surface pro to run inventor
DarrenP
Having had a Surface Pro, I would not recommend using it for Inventor as it does not nearly meet the requirements to run the software properly.
im from italy
i have a macbook air (mid 2013) with 128gb ssd
i have a paralles virtual machine with windows where i have installated autocad and revit for university.
i have to put the virtual machine on a SD:
and the macbook have this:
it will slow or i can use it?
thank you so much
nicola
