During install of inv suite 2010 comes an message as following.
This installation is forbidden by system policy, contact your system administrator.#338
Has someone a solution?
If the machine is not on a domain.
Try a clean installation diagnostics mode logging in as True Administrator.
http://usa.autodesk.com/getdoc/id=TS75218
if it is on a domain, please check for an Group policy blocking installation; %temp%\*.log file should give more information on which part of the registry/file has permission issue.
