Installation & Licensing
install fail 2013 on windows 8
1 REPLY 1
art_turner
268 Views, 1 Reply
i have two users trying to install a home license version premium suite 2013 on windows 8, just sits and spins according to one of them. searching old messages indicates to disable dot net 4 in setup.ini. this is kind of sketchy, not sure where or how far to start deleting lines when dotnet is referenced multiple times. update 2 specifically says it upgrades autocad and inventor 2013 to compatibility with windows 8, but how to install using the same install files that still will not install?
1 REPLY 1
TravisNave
in reply to: art_turner
Have your user provide you with the installation log.  It will help determine the failure.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
