I installed Autodesk moldflow 2013 for win 8, 64 bit students version. There are 3 softwares was installed when installing these products. It's Autodesk Simulation Moldflow Communicator 2013; Autodesk Simulation Moldflow Adviser 2013 and Inventor Fusion 2013. My problem is Autodesk Simulation Moldflow Adviser 2013 software can not open, the error appear like the picture below. Please help me! Thank you so much indeed!!!
Hi @thibkhn and welcome to the Autodesk Community!
Typically this error occurs when:
1. There is no license in the license file,
2. or your installation is not pointing to the correct location for a license,
3. or the server host name is not resolved.
Check out this Autodesk Solution for the complete instructions on how to resolve this error. Please let me know if you need further assistance or please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer.
Thank you!
