Installation & Licensing
Install cant find EULA
12 REPLIES 12
Message 1 of 13
jsrmid
8864 Views, 12 Replies
When installing Autodesk DWG TrueView 2014 on Windows 7 32-bit, I get a message about not finding the EULA. At the point where I click "Install On This Computer" I get a DWG Trueview 2014 window with the message "Can't Find End User License Agreement" my only option is to click ok which closes the install.
I hope someone can help, I've installed this software multiple times and have never ran across this.
12 REPLIES 12
Message 2 of 13
aaronhai
in reply to: jsrmid
Hi jsrmid,
Welcome to Autodesk Discussion Group.
In order to eliminate bad installer issue, may I request for a re-download of the DWG TrueView installer?
Thank you.
Aaron Hai
Message 3 of 13
jsrmid
in reply to: aaronhai
I still receive the same issue. The first time I tried it this morning it allowed me to accept the EULA but the install failed. After I retried the EULA doesnt come up again
Message 4 of 13
TravisNave
in reply to: jsrmid
See if you can physically find the EULA file and move it to where it is expected.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 5 of 13
philip.s
in reply to: jsrmid
Hi Jorge,
Do you experience the same behavior if you bypass the download manager and utilize a direct DWG TrueView 2014 download link?
Message 6 of 13
jsrmid
in reply to: TravisNave
The EULA is in C:\Autodesk\SetupDWGTrueView2014_ENU_32bit\EULA folder, should it be somewhere else? I checked the minimum system requirements and it meets all. I'm running Office 2003, could that be the issue? The EULA is saved as a Word doc
Message 7 of 13
jsrmid
in reply to: philip.s
I Attempted without the installer and used the option to download with the browser instead, it has the same issue. I'm trying to install the 32 bit version
Message 8 of 13
jsrmid
in reply to: jsrmid
This happens on DWG Trueview 2011 version as well
Message 9 of 13
TravisNave
in reply to: jsrmid
And you are not installing outside of your region or with a foreign OS or language, correct?
Autodesk Forums:
Message 10 of 13
jsrmid
in reply to: jsrmid
I was able to successfully install  the software Smiley Very Happy
I opened the Setup.ini document and found a line about the EULA.
EULA_PATH=EULA
Changed it to the correct path
EULA_PATH=C:\Autodesk\SetupDWGTrueView2014_ENU_32bit\EULA
Saved the file and the install worked!
Thanks for the help
Message 11 of 13
TravisNave
in reply to: jsrmid
Excellent job!
Autodesk Forums:
Message 12 of 13
bunny.rambo685
in reply to: jsrmid
i don't fine Desktop.ini file. where to fine it?
Message 13 of 13
@bunny.rambo685
Welcome to the community...
This posting is 2 years old...
"i don't fine Desktop.ini file. where to fine it?"  Doesn't really mean a lot to us.  Give us details of what Autodesk product and version you are trying to install or what you're trying to accomplish here.
Mark Lancaster
Administrator Productivity
