Installation & Licensing
gookeeper
387 Views, 2 Replies
Install Buzzsaw 2012
Hi
I'm having problems installing buzzsaw 2013.1.24.8674 - after installed it says incompatiable version. i had no choice what version to install, its was an automatic install by clicking on a previous version.
I also can't access the web version using the same login data, which seem odd too.
Any Ideas
Guy Smith (CAD Extraordinaire)
2 REPLIES 2
TravisNave
in reply to: gookeeper
Typically this is due to needing either the 32-bit or 64-bit version or a qualifying product already installed on your machine.  Might double-check that you have the right version.
Autodesk Forums:
DAVIDCLARK2244
in reply to: TravisNave
Thanks for the reply, i did have a qualifiing version installed, but it asked me to update to continue, and installed an unusable version. I can not find anywhere, where i can choose a 64bit version. the only downloadable link i can find is below, but that has the same problem.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=9262155
Oh well!
Administrator Productivity
