Installation & Licensing
install AutoCAD 2013 lt insert disc 1
4 REPLIES 4
64406 Views, 4 Replies
Hi
Our customer have problem with instalation package.
He download this from  subscribtion center.
After start instaltion, installer requires "insertion disc 1" (during instalation material library).
Any tips?
Thank for all
4 REPLIES 4
TravisNave
If you copy the entire contents of the installation media to a folder on your local hard disk drive, you will not get prompted for this.
Autodesk Forums:
jake3653
in reply to: TravisNave
I have the same problem and I moved everything to my HDD and I still get the error
ami me pasa lo mismo, y cuando lo copio todo tengo que ejecutar el instalador en el Cd?? o en la carpeta copiada???
in reply to: jake3653
Dear,
Do not copy entire DVD as it is like DVD image. Just open ur DVD and select all files and copy it on Hard Disk with any folder name u like. then Run Setup.exe it will work surely.
Brahma Narayan Sharma
Administrator Productivity
