Installation & Licensing
Active Contributor
martin.vanecek
Message 1 of 5 (39,078 Views)
install AutoCAD 2013 lt insert disc 1
39078 Views, 4 Replies
05-31-2012 02:46 AM
Hi
Our customer have problem with instalation package.
He download this from  subscribtion center.
After start instaltion, installer requires "insertion disc 1" (during instalation material library).
Any tips?
Thank for all
TravisNave
Message 2 of 5 (39,043 Views)
Re: install AutoCAD 2013 lt insert disc 1
05-31-2012 08:14 AM in reply to: martin.vanecek
If you copy the entire contents of the installation media to a folder on your local hard disk drive, you will not get prompted for this.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
jake3653
Message 3 of 5 (28,454 Views)
04-02-2013 01:55 AM in reply to: TravisNave
I have the same problem and I moved everything to my HDD and I still get the error
New Member
jofri28
Message 4 of 5 (11,096 Views)
02-11-2014 04:05 PM in reply to: TravisNave
ami me pasa lo mismo, y cuando lo copio todo tengo que ejecutar el instalador en el Cd?? o en la carpeta copiada???
New Member
brahma.narayan
Message 5 of 5 (2,164 Views)
07-31-2014 01:12 PM in reply to: jake3653
Dear,
Do not copy entire DVD as it is like DVD image. Just open ur DVD and select all files and copy it on Hard Disk with any folder name u like. then Run Setup.exe it will work surely.
Brahma Narayan Sharma
