I cant get Autocad pds 2013 to install, upon setup.exe initlization the program crash report box pops up, no log file is created so I cant even try to solve the problem on my own without some help
Where should I start looking? Could it be a windows update? Is there a list of problematic updates somewhere?
Help =/
Solved by jstrate. Go to Solution.
You can find the log file in your %TEMP% folder.
Thanks but I have been looking in there.
I see the temp directory where it starts unpacking the installer but not a log file.
Fixed the issue, support let me know i had a piece of software that was causing the error. uninstalled it and boom! working now.
I have the same problem.I cannot install autocad 2013.
Please which is the "piece of software that was causing the error"?.
Thanks in advance.
