Installation & Licensing
Member
0 Kudos
Post 1 of 6
Install AutoCad 2013 failed, no log file created
1076 Views, 5 Replies
03-04-2013 02:28 PM
I cant get Autocad pds 2013 to install, upon setup.exe initlization the program crash report box pops up, no log file is created so I cant even try to solve the problem on my own without some help
Where should I start looking? Could it be a windows update? Is there a list of problematic updates somewhere?
Help =/
Fixed the issue, support let me know i had a piece of software that was causing the error. uninstalled it and boom! working now.
893 Kudos
Post 2 of 6
Re: Install AutoCad 2013 failed, no log file created
03-04-2013 02:30 PM in reply to: jstrate
You can find the log file in your %TEMP% folder.
Member
0 Kudos
Post 3 of 6
03-04-2013 02:31 PM in reply to: TravisNave
Thanks but I have been looking in there.
I see the temp directory where it starts unpacking the installer but not a log file.
Member
0 Kudos
Post 4 of 6
03-04-2013 02:44 PM in reply to: jstrate
Member
1 Kudo
Post 5 of 6
05-10-2013 05:26 AM in reply to: jstrate
I have the same problem.I cannot install autocad 2013.
Please which is the "piece of software that was causing the error"?.
Thanks in advance.
Member
0 Kudos
Post 6 of 6
05-10-2013 06:32 AM in reply to: jstrate
It was wireless display software, displaylink i believe
