My pc was destroyed in an office fire, I have licensed upgrades annually since 1999. Having my Serial Number etc. from the 2013 upgrade I purchased the 2014 upgrade but cannot install it on my new pc, what can I do?
what are you trying to install 2013 or 2014?
more detailed info is needed for any help
DarrenP
@DaveG wrote:
I receive a message during the initial install saying:
"The service pack could not be installed because the expected Autodesk product could not be located on your computer."
"Make sure that you are using the correct service pack for the product."
thats because you need to install the product that the service pack is for before you install the service pack
what product is this supposed to be?
DarrenP
During the install process I get a message:
“The service pack could not be installed because the expected Autodesk product could not be located on your computer.”
“Make sure that you are using the correct service pack for the product.”
It is the correct upgrade but won't get to a point for me to input my 2013 version serial number?
@DaveG wrote:
Autocad 2014, I've upgraded annually since 1999, the last version upgraded was 2013?
i don't know what version your supposed to have
you need to confirm with your reseller on what versions you have access to
your downloading/installing just the service pack
the service pack is not the full product
DarrenP
Daren thanks, your help is greatly appreciated. I am at a loss as to get it back, my hard drive and all DVD from original purchase and upgrade DVD's 2013 were burned and I cannot find anywhere related to Autodesk, who has my history of purchases, how to go forward with thier product. My architects use a different program and convert thier drawings to a .dwg format for me to use and look at, I'd rather use what I'm use to than purchase something else.
Have autodesk pull a report on your company here:
http://www.autodesk.com/licensesupport in the drop down menu select pull a report of my licenses
use the chat if possible if not full out the required information on this website
DarrenP
