Installation & Licensing
Install 2nd student version Inventor on one computer
2 REPLIES 2
chaynes6
608 Views, 2 Replies
I live in a student group house, one person has student version Inventor Pro 2012 installed on his hot gaming machine and does not want to upgrade to 2013. Can I install student version Inventor Pro 2013 on his machine and can we both run the different installs (at different times, of course) ? Thanks.
2 REPLIES 2
TravisNave
in reply to: chaynes6
Yes.  They will install on the same machine.  However, Inventor is not backwards compatible, so you cannot share files between the versions.  I would recommend setting yourself up with your own user profile login and installing that way.  Good luck!
Autodesk Forums:
chaynes6
in reply to: TravisNave
Thank you
Administrator Productivity
