2012/12/5:09:28:40 bogann FT-BR-CAD32 Launch
2012/12/5:09:28:52 bogann FT-BR-CAD32 PageOpen LaunchDialog
2012/12/5:09:36:26 bogann FT-BR-CAD32 PageOpen LicenseDialog
2012/12/5:09:36:28 bogann FT-BR-CAD32 PageOpen ProductInfoDialog
2012/12/5:09:38:24 bogann FT-BR-CAD32 PageOpen ProductSelectionDialog2
2012/12/5:09:38:40 bogann FT-BR-CAD32 PageOpen FullProgressDialog
2012/12/5:09:38:40 bogann FT-BR-CAD32 Installing DirectX Runtime: I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/5:09:39:33 bogann FT-BR-CAD32 Install DirectX Runtime Succeeded
2012/12/5:09:39:33 bogann FT-BR-CAD32 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/5:09:40:33 bogann FT-BR-CAD32 Install Autodesk Material Library 2013 Succeeded
2012/12/5:09:40:33 bogann FT-BR-CAD32 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/5:09:41:47 bogann FT-BR-CAD32 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/12/5:09:41:47 bogann FT-BR-CAD32 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/5:09:42:02 bogann FT-BR-CAD32 Install Autodesk Content Service Succeeded
2012/12/5:09:42:02 bogann FT-BR-CAD32 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/5:09:42:18 bogann FT-BR-CAD32 Install Autodesk Content Service Language Pack Succeeded
2012/12/5:09:42:18 bogann FT-BR-CAD32 Installing Microsoft Visual Basic Power Packs 10.0: I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\bogann\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/12/5:09:42:34 bogann FT-BR-CAD32 Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2012/12/5:09:42:36 bogann FT-BR-CAD32 Installing AutoCAD Civil 3D 2013: TRANSFORMS="I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\x64\en-us\C3D\C3D.mst;C:\Users\bogann\AppData\Local\Temp\_AIDEE9.tmp\x64\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\7_FT Deployment (Programs)\Autodesk\AutoCad_Civil3d_2013\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/5:09:42:56 bogann FT-BR-CAD32 Install AutoCAD Civil 3D 2013 Failed Installation aborted, Result=1603
2012/12/5:09:42:56 bogann FT-BR-CAD32 Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2012/12/5:09:43:01 bogann FT-BR-CAD32 Rollback Autodesk Content Service Language Pack Succeeded
2012/12/5:09:43:07 bogann FT-BR-CAD32 Rollback Autodesk Content Service Succeeded
2012/12/5:09:43:20 bogann FT-BR-CAD32 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/12/5:09:44:13 bogann FT-BR-CAD32 Rollback Autodesk Material Library 2013 Succeeded
2012/12/5:09:44:13 bogann FT-BR-CAD32 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
It could be a long path but I doubt it. If you have any AutoCAD 2013 family of products, I would uninstall any of the updates.
1603 = The install failed and it could be anything. You can try putting this in a Google search:
1603 site:http://upandready.typepad.com/
I uninstalled all of the Microsoft C++ packages and tried to install. Still fails to Install. I'm going to try diagnostics mode as I saw in another thread. Here is the latest log file:
2012/12/6:10:39:32 bogann FT-BR-CAD32 === Setup started on FT-BR-CAD32 by bogann ===
2012/12/6:10:39:32 bogann FT-BR-CAD32 Launch
2012/12/6:10:39:48 bogann FT-BR-CAD32 PageOpen LaunchDialog
2012/12/6:10:39:52 bogann FT-BR-CAD32 PageOpen LicenseDialog
2012/12/6:10:39:55 bogann FT-BR-CAD32 PageOpen ProductInfoDialog
2012/12/6:10:41:18 bogann FT-BR-CAD32 PageOpen ProductSelectionDialog2
2012/12/6:10:42:52 bogann FT-BR-CAD32 PageOpen FullProgressDialog
2012/12/6:10:42:52 bogann FT-BR-CAD32 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/12/6:10:43:02 bogann FT-BR-CAD32 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/12/6:10:43:02 bogann FT-BR-CAD32 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/12/6:10:43:18 bogann FT-BR-CAD32 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2012/12/6:10:43:18 bogann FT-BR-CAD32 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\bogann\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/6:10:43:31 bogann FT-BR-CAD32 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/12/6:10:43:31 bogann FT-BR-CAD32 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\bogann\AppData\Local\Temp\vcredist_x64_2010.log
2012/12/6:10:43:43 bogann FT-BR-CAD32 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/12/6:10:43:43 bogann FT-BR-CAD32 Installing DirectX Runtime: C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/6:10:44:29 bogann FT-BR-CAD32 Install DirectX Runtime Succeeded
2012/12/6:10:44:29 bogann FT-BR-CAD32 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/6:10:45:14 bogann FT-BR-CAD32 Install Autodesk Material Library 2013 Succeeded
2012/12/6:10:45:15 bogann FT-BR-CAD32 Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/6:10:45:48 bogann FT-BR-CAD32 Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/12/6:10:45:48 bogann FT-BR-CAD32 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/6:10:46:02 bogann FT-BR-CAD32 Install Autodesk Content Service Succeeded
2012/12/6:10:46:02 bogann FT-BR-CAD32 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/6:10:46:10 bogann FT-BR-CAD32 Install Autodesk Content Service Language Pack Succeeded
2012/12/6:10:46:10 bogann FT-BR-CAD32 Installing Microsoft Visual Basic Power Packs 10.0: C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\bogann\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2012/12/6:10:46:28 bogann FT-BR-CAD32 Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2012/12/6:10:46:29 bogann FT-BR-CAD32 Installing AutoCAD Civil 3D 2013: TRANSFORMS="C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\x64\en-us\C3D\C3D.mst;C:\Users\bogann\AppData\Local\Temp\_AIF8B0.tmp\x64\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Civil3D_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/6:10:46:47 bogann FT-BR-CAD32 Install AutoCAD Civil 3D 2013 Failed Installation aborted, Result=1603
2012/12/6:10:46:48 bogann FT-BR-CAD32 Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2012/12/6:10:46:54 bogann FT-BR-CAD32 Rollback Autodesk Content Service Language Pack Succeeded
2012/12/6:10:47:03 bogann FT-BR-CAD32 Rollback Autodesk Content Service Succeeded
2012/12/6:10:47:32 bogann FT-BR-CAD32 Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/12/6:10:48:27 bogann FT-BR-CAD32 Rollback Autodesk Material Library 2013 Succeeded
2012/12/6:10:48:27 bogann FT-BR-CAD32 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/12/6:10:48:27 bogann FT-BR-CAD32 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2012/12/6:10:48:28 bogann FT-BR-CAD32 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Any Autodesk 2013 update can blog the install. Just unintall it via "Updates" section in the Control Panel.
