Installation & Licensing
michaelskrivanek
118 Views, 1 Reply
Instalation failed
I have a problem with instalation all autodesk programs. When instalation starts, write me error 1603.  I have SSD on programs and HDD for TEMP folders... I have new Windows 8.1.
Thank you for help.
1 REPLY 1
dembkod
in reply to: michaelskrivanek
michaelskrivanek
Hello. You are conflicting with the Microsoft C++ installers. Uninstall the Microsoft C++ from the machine before you run the installer. You will have multiple entries. I would pull them all out.
After this you will likely install just fine.
At this stage, if not, go to the C:\autodesk\ install folder and open the setup.ini file
Search and replace all PREREQ entries with #PREREQ and save the file. Then run the installer.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
