Installation & Licensing
instal max 2010 x 32 on my workstation
1 REPLY 1
jamsurf
132 Views, 1 Reply
Im triying to install max 2010 32 bits on my workstation , i have max201064 and max201264 installed , when i execute the installer , i have no option to install because says me that superior version of software is installed ... , i need the max201032 installed to can use a
plugin that has only plugins for x 32 versions , and the most newer version of pligin is
for max 2010 .
Help please , is urgent !!
1 REPLY 1
TravisNave
in reply to: jamsurf
You cannot install both.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
