Installation & Licensing
Active Member
alistair.heanen
Message 1 of 4 (219 Views)
Infrastructure Design Suite Ultimate 2013 - Included packages/add-on's
219 Views, 3 Replies
08-15-2013 07:49 AM
Could someone please confirm a full list of packages and add-on's included within the Infrastructure Design Suite 2013 edition.
In particular i would like to know if Robot is included with 2013 as it appears to be included with the 2014 edition.
In addition I would also like to know ifthe  Bridge Module is available for 2013 as the subscription centre only appears to offer a 2014 version.
Many thanks
philip.s
Message 2 of 4 (210 Views)
Re: Infrastructure Design Suite Ultimate 2013 - Included packages/add-on's
08-15-2013 08:55 AM in reply to: alistair.heanen
Welcome to the community Alistair!
I wasn't able to find the Design Spreadsheets for Autodesk Robot Structural Analysis Professional 2013 linked to the Infrastructure Design Suite Ultimate entitlements, however it does look like the Bridge Module is available as a component of the  Productivity Tools for AutoCAD Civil 3D 2013.
Philip Schmelzer
Active Member
alistair.heanen
Message 3 of 4 (202 Views)
08-15-2013 09:52 AM in reply to: philip.s
Thank you Philip.
Does this mean Robot is not available pre-2014 or just that it was not included with the IDS Ultimate package?
Also, do you require a Bridge Module add-in for Revit and Civil 3D so there is 2-way integration?
If the Bridge module add-in is not available for Revit 2013 is there a alternative add-in/package that can be used  to quickly model a bridge just within Revit 2013, without the need to use Civil 3D?
philip.s
Message 4 of 4 (167 Views)
08-19-2013 03:33 PM in reply to: alistair.heanen
Sure thing Alistair!
When you say Robot, do you mean the Design Spreadsheets for Autodesk Robot Structural Analysis Professional? The 2014 and 2012 version are listed under entitlements, however there seems to have been a void for 2013.
For the Revit piece, you would want to download the Revit Extensions for Autodesk Revit 2013, which includes bridge tools and Civil 3D 2013 integration.
Philip Schmelzer
