Receiving the following error message during Infrastructure Design Suite Premium 2015 Deployment Creation:
Error 2203. Database:
\\xxxxxx\xxxxxxx\xxxxxxxxx\Computer_Apps\IDSP15installs\Img\x64\ACADExtApps\AutodeskImportSkp.msi Cannot open database file.
System error -2147287008.
Solved by avto. Go to Solution.
The workflow that worked in this particular case was as follows:
A. Download IDSP 2015 installer from Autodesk Virtual Agent Interface, on your workstation (e.g. W7 system)
1.Go to http://upandready.typepad.com/up_and_ready/
2.Click on ASK - this opens Autodesk Virtual Agent window
3.Click on Download Links
4.Click on Autodesk Suites
5.Then on Autodesk Infrastructure Design Suite
6.Select the appropriate product and click the link to download.
B. Create the deployment on the same system you downloaded the IDSP installer.
1.Logon as an Administrator.
2.Empty your TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
3.Disable your Antivirus software.
4.Disable UAC.
http://windows.microsoft.com/en-ca/windows7/turn-user-account-control-on-or-off
5.Create a folder you would like to store your deployment as close to the root of your local drive as you can (e.g. C:\IDSP_2015_DP)
6.Share this folder on your network and give everyone group read/write access
7.Start creating your deployment and specify deployment target folder with UNC path (e.g. \\compNAME\IDSP_2015_DP\)
If you need to move your deployment image to another system, please check this post on our Up and Ready blog.
