Installation & Licensing
Infrastructure Design Suite Premium 2014 trial "File not found."
2 REPLIES 2
3153 Views, 2 Replies
I've been trying to install the Infrastructure Design Suite Premiums 2014 trial for a few days now.  For my initial install attempts, the install would run for hours and would fail with a network error (according to the installer).
The last three times attempts, the install fails before the download starts.
On this page:  http://www.autodesk.com/suites/infrastructure-design-suite/free-trial
I click the "Install Now" button.  Then I accept the license and click "Install".  A "Downloading" web page is loaded briefly, and then a web page that says only:  File not found." is displayed.  The web page url is:  http://www.autodesk.com/suites/infrastructure-design-suite/free-trial.  Refreshing the web page will start the download, but the install ends with a dialog that says that there was a communication failure.
I would appreciate any help getting this installed.
Thanks.
David
2 REPLIES 2
DarrenP
try downloading from here:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Autodesk Suites>Infrastructure Design Suite
Please accept as a solution if this fully resolves the issue
DarrenP
in reply to: DarrenP
The install is not yet complete, but it has gotten much farther than before.
Thanks!
Administrator Productivity
