Installation & Licensing
incorrect data being sent by sender in relation constraint
3 REPLIES 3
286 Views, 3 Replies
I'm getting unpredictable results from a sender (or 2).  They are not sending the correct data through a vector-to-number convert node.  I keep running into problems like this.  How can I know if this relation constraint that I've spent 2 weeks developing will not break?  How can I fix this problem?
3 REPLIES 3
TravisNave
This question would be better asked in the forum for your product.
Autodesk Forums:
in reply to: TravisNave
I thought I was in the forum for Motion Builder... do I go to Technical Support then find MoBu forum? or Discussions?
Can you point me in the right direction?
thanks!
Robert
TravisNave
Certainly.  You will find the information located in this post:
http://forums.autodesk.com/t5/Autodesk-MotionBuilder/Autodesk-MotionBuilder-Discussion-Groups-are-on...
Autodesk Forums:
Administrator Productivity
