Installation & Licensing
*Williams, Bryan
Message 1 of 7 (176 Views)
Inactivity Settings
176 Views, 6 Replies
02-23-2000 01:33 PM
<<< Message <890ut4$cpo11@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.r14general' on Wed, 23 Feb 2000 10:38:07 -0500.>>>
Hi there,
I was wondering if there are any setting within AUTOCAD 14 that allow
for inactivity settings. I'm asking this because we have users who use up
licenses from our server and walk away from their desks and leave ACAD open,
then when actual CAD users need to use the program and we are out of lic.
they cannot work. What I'm thinking is if ACAD had away of detecting say
10min of inactivity it would save the drawing and exit the program,
releasing the license and allowing other people to work.
Bryan Williams
*Ahava, Petri
Message 2 of 7 (176 Views)
Re: Inactivity Settings
02-23-2000 01:33 PM in reply to: *Williams, Bryan
<<< Message <38B41EEE.D4E15A8D@cadcenter.fi> was originally posted to 'autodesk.autocad.r14general' on Wed, 23 Feb 2000 19:54:54 +0200.>>>
yes, you can do this by implementing a socalled Network License Manager Resource
File
. It's really quite easy to do, but as with it you can control a multitude of
things (who cannot use a license, which workstation can't etc) it takes some
time to learn. The instructions are at:
http://www.autodesk.com/support/techdocs/td15/td154044.htm
HTH,
Petri
Bryan Williams wrote:
> Hi there,
> Bryan Williams
*Nehls, Kevin
Message 3 of 7 (176 Views)
Re:
02-23-2000 01:49 PM in reply to: *Williams, Bryan
No. You cannot do this with AdLM, period. What you are thinking about in
the resource file (this can also be done through the GUI) is the "hold
time". What this does is if a user closes AutoCAD and the "hold time"
setting is set to 10 minutes, then the AdLM server will hold that license
for that user for 10 minutes. This would allow a user to reboot their
machine and not lose their license.
If you want to control the licenses better than the AdLM can, you need a
third party program to do so. Here is an copy of a post in the "Taking
back licenses if there is inactivity" thread.
Hi Jacob,
we are using the licensing software KeyServer from Sassafras
(www.sassafras.com). The AdLM controlls the numbers of licenses and the
KeyServer checks if the program is idle for a specified time.
Hope this will help you.
Frank Junggeburth
Kevin Nehls
for reply remove -ns-
Petri Ahava wrote in article
<891jnq$fen24@adesknews2.autodesk.com>...
> Hi,
Resource
> File
(snip)
*Ahava, Petri
Message 4 of 7 (176 Views)
Re:
02-23-2000 02:05 PM in reply to: *Williams, Bryan
sorry 'bout the bloop. No excuse, a mistake (done and read the manual again 's
what I did...)
Again S'rry
Petri
> Hi Jacob,
> Frank Junggeburth
> Kevin Nehls
> > Hi,
> Resource
> > File
> (snip)
*Nehls, Kevin
Message 5 of 7 (176 Views)
Re:
02-23-2000 02:25 PM in reply to: *Williams, Bryan
No problem. I wish that you could do this with AdLM out of the box. If
you can "Bury" a client without them losing data (someone correct me here
if I am wrong), then why can't you have it setup so that the AdLM can
automatically pull a license? If they are worried about added network
overhead from AutoCAD and the AdLM having to constantly communicate then
why don't they it setup so that AutoCAD (if it is in use) sends a message
to the AdLM server at a percentage of whatever the "timeout" setting is.
Or have it the other way around and have AutoCAD only respond back to the
AdLM server if it is being used. Maybe on the next release. :-)
Kevin Nehls
<38B459A9.78769AFE@cadcenter.fi>...
> Hi,
again 's
> what I did...)
> Again S'rry
> Petri
*Ahava, Petri
Message 6 of 7 (176 Views)
Re:
02-23-2000 02:38 PM in reply to: *Williams, Bryan
I agree Kevin!
I mean what would be the actual nw overhead be using TCP/IP, I mean most of
the users are already on the i-net and no-one is complaining (except maybe
the topbrass)?
Petri
> Kevin Nehls
> > Hi,
> again 's
> > what I did...)
> > Again S'rry
> > Petri
*Michl, Vladimir
Message 7 of 7 (176 Views)
04-27-2000 01:09 AM in reply to: *Williams, Bryan
See the LogOff utility - http://www.cadstudio.cz/logoff
> Hi there,
> Bryan Williams
Vladimir Michl
CAD Studio s.r.o. - Autodesk Systems Center, HP Authorized Dealer
AutoCAD application development
vmichl@cadstudio.cz http://www.cadstudio.cz
Tylova 17, 370 01 Ceske Budejovice, Czech Rep.
tel. +420-38-6352966 fax. +420-38-6352979 BBS +420-38-6352962
