I have downloaded Acad LT 2011 (64bit), but I can't install it. The problem comes from the .NET Framework, it seems that it should be the 3.5 SP 1 version and I'm running version 4. So I tried to uninstall version 4 and reinstall an earlier version. But It doesn't work although I have uninstalled Framework 4 and clean it all, when I try to install an earlier version (3.0) Windows just consider the Framework 4 is still on my computer.
So my questions are :
Is it realy a problem with Framework 4?
If yes, how do I get out of it?
Which operating system are you trying to install AutoCAD LT 2011 (64 bit) on?
Do you receive any error message while installing? If so, please attach a screen shot of the same.
In the operating system if Microsoft .net framework 4 is built in (For Ex. Windows 7) the .net framework 3.5 SP 1
should install without a problem as must be the case with the entire installation.
My system is Windows 7 Home premium
The installation of .NET Framework 3.5 SP1 and Visual C++ just fail and the installation just not go further.
The error message refers to a .log file that contains the following :
'2010/9/10:10:35:10 FRED PC === Setup started on FRED-PC by FRED ===
2010/9/10:10:35:51 FRED PC Install .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1603
2010/9/10:10:35:55 FRED PC Install .NET Framework 3.5 SP1 Update KB958484 Failed Failure is ignored, Result=1603
2010/9/10:10:36:02 FRED PC Install Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1603'
I tried to uninstall the framework 4 but when I try reinstall the version 3.0 windows just tells me that a more recent version is installed.
The Result=1603 essentially indicates insufficient rights as a user to install
applications/components.
Make sure you are entitled full permissions as a user before carrying out installation.
If this does not resolve try the following alternatives:
1. Check if installing the Windows Installer 4.5 resolves the issue.
http://support.microsoft.com/kb/942288
2. Download the Microsoft vc ++ redistributable from the link below to see if it helps.
http://www.microsoft.com/downloads/en/details.aspx?familyid=a5c84275-3b97-4ab7-a40d-
3802b2af5fc2&displaylang=en
3. Create a new Windows User Account is created (With administrative rights) and try installing.
