After having all remove the previous installation interrupted (as explain in the support), impossible to install ! Msg = already installed/ fi you want to install french... (because i'm french)
Do you have an idea please ?
You will need to start all over again. You probably did not remove ALL traces of autocad on your PC. Go into your registry and look for anything related to autocad and delete it. That is the only way you can reinstall, the existing files may be hiding somewhere. Keep looking.....
