Installation & Licensing
IDSP 2014 install will not fininsh
7 REPLIES 7
Message 1 of 8
Joe-Bouza
635 Views, 7 Replies
Hi
I created my deployment and ran the installation and this has been on my screen for about 4 hours now.
What is it and should I cancel it? Note task manager says it is running
Your Name
Your Name
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: Joe-Bouza
Good question...
This isn't a silent deploy is it?
Also, is there anything in the installation log at that real-time moment that shows it's stuck on something?
Autodesk Forums:
Message 3 of 8
Joe-Bouza
in reply to: TravisNave
Silent install.
this is in the log:
2013/9/20:07:56:02 JBouza CE-WKS54 === Setup started on CE-WKS54 by JBouza ===
2013/9/20:07:56:02 JBouza CE-WKS54 Path_Length: 155
2013/9/20:07:56:02 JBouza CE-WKS54 Current Directory \\CE-FILES\CAD Install Deployments\2014 IDSP\Img
2013/9/20:07:56:02 JBouza CE-WKS54 Launch
2013/9/20:07:56:02 JBouza CE-WKS54 CommandLine /qb /I \\CE-FILES\CAD Install Deployments\2014 IDSP\Img\IDSP 2014.ini /language en-us
2013/9/20:07:56:02 JBouza CE-WKS54 Current Directory C:\Users\jbouza\AppData\Local\Temp\_AI888B.tmp
2013/9/20:07:56:31 JBouza CE-WKS54 === Setup ended ===
2013/9/20:08:06:50 JBouza CE-WKS54 === Setup started on CE-WKS54 by JBouza ===
2013/9/20:08:06:50 JBouza CE-WKS54 Path_Length: 155
2013/9/20:08:06:50 JBouza CE-WKS54 Current Directory \\CE-FILES\CAD Install Deployments\2014 IDSP\Img
2013/9/20:08:06:50 JBouza CE-WKS54 Launch
2013/9/20:08:06:50 JBouza CE-WKS54 CommandLine /qb /I \\CE-FILES\CAD Install Deployments\2014 IDSP\Img\IDSP 2014.ini /language en-us
2013/9/20:08:06:50 JBouza CE-WKS54 Current Directory C:\Users\jbouza\AppData\Local\Temp\_AIE648.tmp
2013/9/20:08:07:08 JBouza CE-WKS54 === Setup ended ===
Your Name
Your Name
Message 4 of 8
TravisNave
It might work better if it is not a silent deploy.  The only other thing that stands out is the potential that your UNC path may be too long during some point in the install.
Autodesk Forums:
Message 5 of 8
Joe-Bouza
Why is the UNC length 155 ? how can I shorten it its the only server I have to keep the deployments.
Your Name
Your Name
Message 6 of 8
TravisNave
I'd just shorten the share name and keep it one share deep and no more.
\\server\share. Recreate it as not silent that way then test. It it works,
modify it for silent and try again.
Autodesk Forums:
Message 7 of 8
emily.xu
Travis is right, we don't recommend to install under silent mode, so we can check where is the installation stuck or fail.
Another suggestion from me is to disable anti-virus , not only can it slow down the installation process, but it can actually introduce corruption. So make sure that your virus checking software is turned off before you install, and make sure you turn it back on when you're complete.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Message 8 of 8
Joe-Bouza
I don't think the dialog box caused a problem. The license errors I was recieving went away. IT told me they updated the License and they did not. Sometime you have to take the bull by the horns all the way into the barn.
Thank you all for the advice I am taking the silent mode off in the deplotment.
Your Name
Your Name
Administrator Productivity
