Installation & Licensing
IDS 2013 Error 25003: Failed to to go to next file inside of ZIP file
3 REPLIES 3
1896 Views, 3 Replies
Autodesk Ifrastructure Design Suite 2013 Install Error 25003: Failed to to go to next file inside of ZIP file
F:\x64\en-us\C#D\Program Files\Root\Help\C3D2013Help.zip
I have attached install log files for reference.
3 REPLIES 3
1. Copied the files from the USB  drive to the local drive and tried to reinstall the software. I have had the same results with the software failing during the installation.
2. Fails duringthe AutoCAD Civil 3D 2013 Language Pack
3. Renamed the all Folders related to AutoDesk/ AutoCAD by adding "_" to the Folder name (Example: _Autodesk)
cad4us
I'm seeing the exact same type of error on few of our 2014 deployments.
One of the install log files has the line:
Error 25003. Unzip Error: Failed to go to next file inside of ZIP file .... \acad\English\HelpHtml.zip
The ACAD version is ACAD Arch 2014 with the offline help being installed.
Needless to say, the install bombs out at that point.
I'm wondering if this is a corrupt file, or generic ZIP error. I'm not really sure yet.
Keith
in reply to: cad4us
>From what I remember and my apologies for not updating this when I solved
it. I think I copied the USB drive contents to the local drive and ran the
install. Seemed like an issue while trying to extract the install files
during installation.
Also as an additional option try to do a custom install for some reason I
think that was what helped me
Administrator Productivity
