I had Inventor 2015 Professional installed on my computer, student version. Everything worked fine but I lacked space and de-installed it.
I am now trying to reinstall it, but there is some kind of red icon in front of the Invenstor 2015 Pro when I try to re-install.
How shall I solve thios problem?
What does the red icon state when you hover over it with your mouse?
It said "You must first uninstall Eco Materials Advisor for Autodesk Inventor 2015".
Fair enough. Shall try to re-install again.
Still unable to install.
Installation complete. SOme products failed to install.
Audodesk Inventor 2015
Autodesk Revit Interoperability for Inventor 2015, and
Autodesk Inventor Content Library
Installation log file attached.
Install Autodesk® Inventor® 2015 Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
I did as You suggested. Initially I got a blue screen, but after some attempts it finally worked.
Thanks for the support!
