I am ready to blow a cork!
I have been trying to get my IDSP deplyment set for weeks and keep hitting one road block after the next.
First I make a deployment and the civil3d component does not work. SR has me download solo civil3d it worked but the raster component on to of c3d didn't
so it worked on my work station but none other in the office
next I get forum advise from my log file the path said 155 characters, that this may be causing the problem. I get the deployment folder as close to the root as I can, still no good
next delet the deployment and get media from adsk, no good, advise : dont create directly from media copy to desktop first. Ok delete the deployment, copy media and the freaking thing fails on Sanitar sewers. I could have walked areound to 50 workstations and installed from media in the time wasted.
I don't even have a question just needed a place to complain
Your Name
Solved by Joe-Bouza. Go to Solution.
If you can't even copy the media to the desktop there is probably either a problem with the media or you have an antivirus software that is blocking the file. What file is it getting stuck on and what Antivirus is running?
Your Name
Well Viper is definately off, and now I get some odd widows error messages priot to failure: Is our server at fault?
Your Name
I am wondering if it is not rolder length / depth causing the issue. You might just try \\cd-files\IDSP as your UNC just for a test.
Well I thought I got it knocked. I shortened the UNC, disabled Viper, made sure I had rights and the deployment went through. Although there was a windows hicup, and after the fact I have come to realize that raster design is not part of the deployment, which is no good. Its not a check box issue its just not in the list. Can I get it back? Admittedly, our server does have some switch issues they have been working on. I'm thinking the last thing to do is try to create directly on the server instead of remotely from my workstation?
Your Name
I have the Midas touch!
So figured I'll try to download another copy of the software, so I wait 2 hrs for it to download, click on the exe file and get informed that "All files did not download try again"
Good thing I don't work for the post office
Your Name
Your Name
