I have an old 3ds max 9 that I haven't been able to run on my new Windows 7 format. I am hoping to find some kind of downloadable 'bridge' that will fix it and let me work again. Any suggestions?
DarrenP
I get an application error "The application was unable to start correctly (0xc0000005). Click to close the application.
again this version was not made to run on Windows 7
it didn't even work on vista without service packs you can try running in xp mode on windows 7
DarrenP
or you can try compatibility mode
DarrenP
Yes. I have one plugged into the computer. Do you think that may be the problem? I have it installed. It is opening it that is the problem. I think the problem has to do with the program being designed for XP and I am trying to use Windows 7. Do you think that makes sense?
