Installation & Licensing
i cant install revit architecture 2012....i tried so many times!!!!
1 REPLY 1
jason_limpiada
248 Views, 1 Reply
this is the log after i install revit architecture.so what is the solution for this?!
2013/4/3:20:23:55 LIMPIADA-PC LIMPIADA === Setup started on LIMPIADA by LIMPIADA-PC ===
2013/4/3:20:23:55 LIMPIADA-PC LIMPIADA Launch
2013/4/3:20:24:13 LIMPIADA-PC LIMPIADA PageOpen LaunchDialog
2013/4/3:20:28:06 LIMPIADA-PC LIMPIADA PageOpen LicenseDialog
2013/4/3:20:32:00 LIMPIADA-PC LIMPIADA PageOpen ProductInfoDialog
2013/4/3:20:32:39 LIMPIADA-PC LIMPIADA PageOpen ProductSelectionDialog2
2013/4/3:20:32:47 LIMPIADA-PC LIMPIADA PageOpen FullProgressDialog
2013/4/3:20:32:47 LIMPIADA-PC LIMPIADA Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Users\LIMPIA~1\AppData\Local\Temp\Rar$EXa0.176\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\LIMPIA~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/4/3:20:32:55 LIMPIADA-PC LIMPIADA Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2013/4/3:20:32:55 LIMPIADA-PC LIMPIADA PageOpen InstallCompleteDialog
2013/4/3:20:33:53 LIMPIADA-PC LIMPIADA === Setup ended ===
2013/4/3:20:23:54 LIMPIADA-PC LIMPIADA === Setup started on LIMPIADA by LIMPIADA-PC ===
2013/4/3:20:23:54 LIMPIADA-PC LIMPIADA Launch
2013/4/3:20:33:54 LIMPIADA-PC LIMPIADA === Setup ended ===
2013/4/3:21:16:43 LIMPIADA-PC LIMPIADA === Setup started on LIMPIADA by LIMPIADA-PC ===
2013/4/3:21:16:43 LIMPIADA-PC LIMPIADA Launch
2013/4/3:21:16:57 LIMPIADA-PC LIMPIADA PageOpen LaunchDialog
2013/4/3:21:17:46 LIMPIADA-PC LIMPIADA PageOpen LicenseDialog
2013/4/3:21:17:52 LIMPIADA-PC LIMPIADA PageOpen ProductInfoDialog
2013/4/3:21:18:16 LIMPIADA-PC LIMPIADA PageOpen ProductSelectionDialog2
2013/4/3:21:18:31 LIMPIADA-PC LIMPIADA PageOpen FullProgressDialog
2013/4/3:21:18:31 LIMPIADA-PC LIMPIADA Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Users\LIMPIA~1\AppData\Local\Temp\Rar$EXa0.113\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\LIMPIA~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/4/3:21:18:37 LIMPIADA-PC LIMPIADA Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2013/4/3:21:18:37 LIMPIADA-PC LIMPIADA PageOpen InstallCompleteDialog
2013/4/3:21:36:20 LIMPIADA-PC LIMPIADA === Setup ended ===
2013/4/3:21:16:40 LIMPIADA-PC LIMPIADA === Setup started on LIMPIADA by LIMPIADA-PC ===
2013/4/3:21:16:40 LIMPIADA-PC LIMPIADA Launch
2013/4/3:21:36:21 LIMPIADA-PC LIMPIADA === Setup ended ===
2013/4/6:07:42:17 LIMPIADA-PC LIMPIADA === Setup started on LIMPIADA by LIMPIADA-PC ===
2013/4/6:07:42:17 LIMPIADA-PC LIMPIADA Launch
2013/4/6:07:42:47 LIMPIADA-PC LIMPIADA === Setup ended ===
2013/4/6:07:42:19 LIMPIADA-PC LIMPIADA === Setup started on LIMPIADA by LIMPIADA-PC ===
2013/4/6:07:42:19 LIMPIADA-PC LIMPIADA Launch
2013/4/6:07:42:38 LIMPIADA-PC LIMPIADA PageOpen LaunchDialog
2013/4/6:07:43:32 LIMPIADA-PC LIMPIADA PageOpen LicenseDialog
2013/4/6:07:43:52 LIMPIADA-PC LIMPIADA PageOpen ProductInfoDialog
2013/4/6:07:49:33 LIMPIADA-PC LIMPIADA PageOpen ProductSelectionDialog2
2013/4/6:07:49:42 LIMPIADA-PC LIMPIADA PageOpen FullProgressDialog
2013/4/6:07:49:43 LIMPIADA-PC LIMPIADA Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\LIMPIA~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/4/6:07:49:49 LIMPIADA-PC LIMPIADA Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
1 REPLY 1
asburyj
in reply to: jason_limpiada
The install is failing installing the VC++ 2010 prerequsiste software as noted in your setup log " Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603"
Since you are installing an older version it may be your system has a newer version of the Visual C++ 2010 installed that the Revit installer doesn't recognize but is blocking the install of the version included with Revit. To workaround this issue please try uninstalling any version of Microsoft Visual C++ 2010 from your system and try the Revit install again.
Jeffry Asbury
Administrator Productivity
