2014/11/19:00:05:16 eloy ELOY-PC === Setup started on ELOY-PC by eloy ===
2014/11/19:00:05:16 eloy ELOY-PC Launch
2014/11/19:00:05:16 eloy ELOY-PC CommandLine
2014/11/19:00:05:23 eloy ELOY-PC === Setup ended ===
2014/11/19:00:05:19 eloy ELOY-PC === Setup started on ELOY-PC by eloy ===
2014/11/19:00:05:19 eloy ELOY-PC Launch
2014/11/19:00:05:23 eloy ELOY-PC PageOpen LaunchDialog
2014/11/19:00:05:30 eloy ELOY-PC PageOpen LicenseDialog
2014/11/19:00:05:36 eloy ELOY-PC PageOpen ProductInfoDialog
2014/11/19:00:06:42 eloy ELOY-PC PageOpen ProductSelectionDialog2
2014/11/19:00:07:36 eloy ELOY-PC PageOpen FullProgressDialog
2014/11/19:00:07:36 eloy ELOY-PC Installing DirectX Runtime: "C:\Autodesk\Autodesk_Simulation_CFD_2014_Multilingual_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/11/19:00:08:11 eloy ELOY-PC Install DirectX Runtime Succeeded
2014/11/19:00:08:11 eloy ELOY-PC Installing Autodesk® Inventor Fusion 2013 R1: TRANSFORMS="C:\Users\eloy\AppData\Local\Temp\_AI8176.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Simulation_CFD_2014_Multilingual_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2013 R1\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/19:00:10:17 eloy ELOY-PC Install Autodesk® Inventor Fusion 2013 R1 Succeeded
2014/11/19:00:10:17 eloy ELOY-PC Installing Network License Manager: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Simulation CFD" SETUP_PACKAGECODE={4F48608F-920C-4020-B262-A3018301DD99} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Simulation_CFD_2014_Multilingual_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/19:00:10:20 eloy ELOY-PC Install Network License Manager Succeeded
2014/11/19:00:10:20 eloy ELOY-PC Installing Microsoft WSE 3.0: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Simulation CFD" SETUP_PACKAGECODE={4F48608F-920C-4020-B262-A3018301DD99} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 3.5 SP1,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Simulation_CFD_2014_Multilingual_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/19:00:10:26 eloy ELOY-PC Install Microsoft WSE 3.0 Succeeded
2014/11/19:00:10:26 eloy ELOY-PC Installing Autodesk® Simulation CFD 2014: TRANSFORMS="C:\Users\eloy\AppData\Local\Temp\_AI8176.tmp\x64\Simulation CFD Setup x64-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Simulation_CFD_2014_Multilingual_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Simulation CFD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/11/19:00:11:51 eloy ELOY-PC Install Autodesk® Simulation CFD 2014 Failed Installation aborted, Result=1603
2014/11/19:00:11:56 eloy ELOY-PC Rollback Microsoft WSE 3.0 Succeeded
2014/11/19:00:11:58 eloy ELOY-PC Rollback Network License Manager Succeeded
2014/11/19:00:12:24 eloy ELOY-PC Rollback Autodesk® Inventor Fusion 2013 R1 Succeeded
2014/11/19:00:12:24 eloy ELOY-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
When started the program , he said:
A material database file was not found
Verify that "matprop.cfdmdb" exists in C:\ProgramData\Autodesk\simulation CFD 2013.
NO, i create , matprop.mdb, to matprop.cfdmdb. NEXT
FAIL
If the condition persist, delete cfdesign_db_dictionary.xml file located in you username appdata local simulation cfd folder,
NOT EXIST, i cant delete
NEXT
Note that this can occur if oyur user acount was created after autodesk simulation cfd was installed.
I dont know , How config the CFdConfig from Program files Autodesk Simulation CFD, Im not a programmer.
NEXT I click on More Informacion, Server not found C:/Program Files/Autodesk/Simulation CFD 2014/Material Database.
HELP Please. The ID and key is good
Hi EloyBB,
Sounds like you might have a corrupt install. To resolve this issue please try the following soluiton.
Please uninstall Using the Microsoft fix it tool.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
1.) Click the "Run now" button in the Fix-it box.
2.) Accept the License Agreement.
3.) Choose the option "Detect Problems and let me select fixes to apply".
4.) Select "Uninstalling".
5.) When the list of installed programs populates, select the one from the list you are unable to reinstall and then click Next and Yes.
6.) When the tool completes there may be remnants left so please delete the directory where the product was installed.
Next, delete the leftover files locaetd in
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\Simulation CFD 2014
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\Simulation CFD 2014
Prior to running the installer please make sure to complete steps.
- Make sure you are logged in as the System Administrator.
- Disable User Account Control settings.
http://windows.microsoft.com/en-us/windows/turn-user-account-control-on-off#1TC=windows-7
- Disable Antivirus software.
- Clean temp directory.
After completing the steps please try reinstalling.
