Installation & Licensing
I can't run Autodesk Simulation Multiphysics 2012 here, what should I do?
2 REPLIES 2
442 Views, 2 Replies
Hi, I'd installed "Autodesk Simulation Multiphysics 2012" from Autodesk site when I was looking for Algor. I signed in and taked a Serial Number and a Product Key.
After some days, the softwares isn't running. It was reinstalled, but this message keeps be shown:
The first time, this: "You are attempting to run a version of Autodesk Simulation other than the one last registered on this system(). Only one version can be registered at a time.
To use this version, you must first exit all other copies of Autodesk Algor Simulation"
And then: "You are attempting to run a version of Autodesk Simulation other than the one last registered on this system(). Only one version can be registered at a time.
Would you like to try to register this version now?"
I cliked yes, but:
"Registering this version of Autodesk Simulation
Please wait"
"want to allow the program to then make changes to this computer?
Program Name: Registry Editor
supplier checked: Microsoft Windows"
(Yes, 6 times)
"Unexpected error; quitting" (OK, 4 times)
Finally:
"Autodesk Simulation is not registerd correctly. Please use the Add/Remove Programs option in the Control Panel to repair the installation"
Once, it oppened, but I could not open the tutorial. When I looked for help, it showed:
"To Activate Autodesk Simulation 2012:
    Start Autodesk Simulation and select the Activate button.
    Log in using your Autodesk User ID account. If you do not have an account, you can create one".
 But I couldn't find the "Activate button".
So, how can I use the software?
Tags (2)
2 REPLIES 2
Thanks, I've found the solution in a Help pdf, this is how to find the activation button: help/about/product information/activate.
I think it's ok now.
No, it doesn't work. Unfortunately the problem remains.
Administrator Productivity
