Installation & Licensing
fire94210
292 Views, 6 Replies
I can not install MAYA
When I installed MAYA, he would not let me install, how to solve?
6 REPLIES 6
ampster401
in reply to: fire94210
what do any of the installation log files show?
fire94210
in reply to: ampster401
this is install files
ampster401
both directx and c++ are failing.  Hopefully that is enough for someone else to help guide you thru this as I do not know if manually installing both of those components would work or not.
fire94210
thanks but how to manually installing both of those components ?
TravisNave
Here is the actual error from your log file:
Download Failed, Installation aborted, Result=1603
 I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
fire94210
in reply to: TravisNave
Thank you very much,I have to re-install and can de used 🙂
Administrator Productivity
