Installation & Licensing
I can not install AutoCAD.
16 REPLIES 16
Message 1 of 17
943 Views, 16 Replies
Sorry for repeating myself but I was just not getting an answer to my question.
Regarding the reply you gave me it did not seam to be the best way to fix my problem because they said that this program may corrupt other programs I have already installed in my computer.  Do you know what other file names I can delete from my registry besides Autodesk & AutoCAD that will eliminate this deadlock?  Or, do you have any otter ideas?
16 REPLIES 16
Message 2 of 17
TravisNave
Message 3 of 17
Have you personally run this program?  Because it does not work. Do you have any other suggestions?
Message 4 of 17
TravisNave
I personally run it many times a day while providing customer support.  I highly recommend it as a workable solution to your issue.  I understand your concerns, but so long as you use it as directed, you will have no problems.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 5 of 17
TravisNave
Run the MSI Cleanup, remove your AutoCAD version from the list.  Then from Windows Explorer, delete the AutoCAD direction from Program Files.  Then reboot.  You should be able to successfully reinstall AutoCAD just like it was never installed before.
Autodesk Forums:
Message 6 of 17
in reply to: TravisNave
Please! Please! Please! Give me the direct link to this download program because I can not decipher what your other link is talking about.
Message 7 of 17
What I meant by this program does not work is this program will not download into my computer.  What can I do about this?
Message 8 of 17
TravisNave
I provided the file for download on the second page of that discussion question.
Autodesk Forums:
Message 9 of 17
TravisNave
Here, I will provide it again for you.  Unzip and install the msicuu2.exe.  You can then run the program from your Start Menu.
Autodesk Forums:
Message 10 of 17
Thank you for your help. I am still having a problem. After installing and running the repair program I was able to start to install AutoCAD but it will only go to Installing Components, AutoCAD 2010 and it stays there indefinitely.  I think it's because of me going into the registry removing practically everything that had the words Autodesk & AutoCAD attached to it, including folders.  I did a Windows repair and this did not fix the problem.
Message 11 of 17
TravisNave
Did you actually run the utility and remove AutoCAD 2010 from the list?
Autodesk Forums:
Message 12 of 17
Yes, I removed the AutoCAD entry only.
Message 13 of 17
TravisNave
Then all you need to do is remove the AutoCAD 2010 folder under Program Files, reboot, and try the reinstall.
Autodesk Forums:
Message 14 of 17
Well I am getting the green install bar across the bottom that I did not get before, thats a good thing.  I think it's going to work!  You are a mastermind, it worked!!!  Tank you! Thank you! Thank you!
Message 15 of 17
TravisNave
That's how I roll.  Good luck and hope everything works for ya!
Autodesk Forums:
Message 16 of 17
Hi.  I cannot install AutoCAD either.  It keeps asking for deployment information, which I understand to be for multiple computers - but it could mean other things that I don't know about...
If I download it again, would it take up that much more space - duplicating what's already been downloaded - on my computer?  It's already a huge program.
Any advice as to what to do next?  Re-install?  or ????
Message 17 of 17
TravisNave
Did you download the file from the Autodesk Subscription center?  You should just be able to extract the downloaded files and run setup.exe.  From there, the autorun install menu should launch.  What kind of error are you getting?
Autodesk Forums:
Administrator Productivity
