Installation & Licensing
Valued Mentor
mdhutchinson
Message 1 of 6 (229 Views)
I can not any longer submit a support case???
229 Views, 5 Replies
07-19-2013 12:29 PM
Don't know if this is the beet place for this... but since I cannot post a support case.. it was the best option.
For some reason I cannot any longer submit a support case on our Subscription web site. After clicking on 'Select a Case Type' the 'Progressing..' spinning wheel runs without interuption and never finishes.
I had Imaginit log a support case for me... but have not heard anything yet.
Is anyone else seeing this... issue with this relatively new interface?
ooh.... I might have gotten a support case posted... but then again maybe not.
See the attached images.
ooh... I have Internet Explorer 9
Content service is a search tool which runs as a service outside of AutoCAD, building an index for specified locations.  That way, when you use the Content Service to search for text in a title block, or have a certain block insert, etc. it doesn't actually search the files (which can take some time) but looks it up in the index system.
If you are a sole-user without any grunts/assistants to handle simple tasks it might serve some use, but a well organized file system will render most of its advantages moot.
pendean
Message 2 of 6 (219 Views)
Re: I can not any longer submit a support case???
07-19-2013 12:55 PM in reply to: mdhutchinson
It's been stalling here since Wednesday too.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
TravisNave
Message 3 of 6 (213 Views)
07-19-2013 01:35 PM in reply to: mdhutchinson
So, what do you actually need support with?  The community might be able to assist.
Valued Mentor
mdhutchinson
Message 4 of 6 (206 Views)
07-19-2013 02:42 PM in reply to: TravisNave
I am gearing up for 2014 rollout... I've built deployments and have successfully eliminated Autodesk 360 via manual ini file edits... I am now wondering how to go about eliminating Autodesk Sync. Is't Autodesk Sync part of Autodesk 360? And what is Content Service?  Of what use is it?
DarrenP
Message 5 of 6 (203 Views)
07-19-2013 03:05 PM in reply to: mdhutchinson
yes autodesk sync is autodesk 360 if you removed adsync from the setup.ini it will not install autodesk 360
i can't answer the what is content service question
dgorsman
Message 6 of 6 (197 Views)
07-19-2013 03:29 PM in reply to: DarrenP
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
