I created a Student account today and tried to download the 2015 Autodesk Inventor. I used the Install Now option because I want to install the program on this computer. However, after it downloaded and I started the installation, it immediately shows all of the programs with red x's and it says "Installation complete. Some products failed to install." I read that this may be a firewall problem, so I completely disabled my firewall during the installation. After several times, it never worked. How do I fix this?
Nathaniel,
Follow the troubleshooting steps from here. If that doesn't work for you, uninstall and remove the software from the machine and download the software again from our Virtual Agent.
I have tried uninstalling the Microsoft Visual C++ 2005, which is listed as the failure in the install log. However, this did nothing. I attached the install log so you can see what the problem is. What should I do?
2014/9/6:21:21:35 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/6:21:21:35 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:21:21:35 Nathaniel NATHANIEL-PC Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US 2014/9/6:21:21:35 Nathaniel NATHANIEL-PC Launch 2014/9/6:21:21:35 Nathaniel NATHANIEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49991961 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/6:21:21:35 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:21:21:35 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AIBF62.tmp 2014/9/6:21:26:53 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/6:21:21:38 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/6:21:21:38 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:21:21:38 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AIBF62.tmp 2014/9/6:21:21:38 Nathaniel NATHANIEL-PC Launch 2014/9/6:21:21:41 Nathaniel NATHANIEL-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6... 2014/9/6:21:26:52 Nathaniel NATHANIEL-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6... 2014/9/6:21:26:52 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AIBF62.tmp\Setup\InventorUI.dll 2014/9/6:21:26:52 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:21:26:53 Nathaniel NATHANIEL-PC PageOpen LaunchDialog 2014/9/6:21:27:56 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AIBF62.tmp\Setup\InventorUI.dll 2014/9/6:21:27:56 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:21:27:56 Nathaniel NATHANIEL-PC Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/6:21:27:56 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AIBF62.tmp\Setup\InventorUI.dll 2014/9/6:21:27:56 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:21:27:56 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2014/9/6:21:27:57 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/6:21:31:06 Nathaniel NATHANIEL-PC PageOpen LicenseDialog 2014/9/6:21:31:06 Nathaniel NATHANIEL-PC PageOpen ProductInfoDialog 2014/9/6:21:31:06 Nathaniel NATHANIEL-PC PageOpen InventorFlavorSelectionDialog 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==DefaultLanguage: en-us 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==InstallName: INVENTOR 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==ProductName: Autodesk Inventor 2015 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==DisplayName: AutodeskĀ® InventorĀ® 2015 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==DeploymentName: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==SetupTitle: Autodesk Inventor 2015 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==ConfigTransform: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==ExeParams: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4} 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==SupportLink: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==InfotainmentLink: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==MsiFileName: inventor.msi 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==AdminImageConfigName: Imgx64 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==AdminImageRoot: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==GetBaseDeploymentName: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==DeploymentLocation: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==InstallDeploymentShortcut: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==ModifyDeploymentShortcut: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==SetupLockType: 2 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==SetupNetworkType: 1 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==SystemLocale: 1033 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==EvalMsiFilePath: C:\Users\NATHAN~1\AppData\Local\Temp\_AIBF62.tmp\SetupRes\eval.msi 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==InstallLogPath: C:\Users\NATHAN~1\AppData\Local\Temp\Inventor2015Install.log 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==ConfigFile: C:\Users\NATHAN~1\AppData\Local\Temp\_AIBF62.tmp\Setup.ini 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==SetupPath: C:\Users\NATHAN~1\AppData\Local\Temp\_AIBF62.tmp\ 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==NetworkLogPath: 2014/9/6:21:31:07 Nathaniel NATHANIEL-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015 2014/9/6:21:40:04 Nathaniel NATHANIEL-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2014/9/6:21:40:04 Nathaniel NATHANIEL-PC PageOpen ProductSelectionDialog2 2014/9/6:21:40:23 Nathaniel NATHANIEL-PC PageOpen FullProgressDialog 2014/9/6:21:40:24 Nathaniel NATHANIEL-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST... 2014/9/6:21:40:39 Nathaniel NATHANIEL-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST... 2014/9/6:21:40:39 Nathaniel NATHANIEL-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\NATHAN~1\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/9/6:21:40:55 Nathaniel NATHANIEL-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603 2014/9/6:21:40:56 Nathaniel NATHANIEL-PC PageOpen InstallCompleteDialog 2014/9/6:21:47:46 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/6:21:58:28 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/6:21:58:28 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:21:58:28 Nathaniel NATHANIEL-PC Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US 2014/9/6:21:58:28 Nathaniel NATHANIEL-PC Launch 2014/9/6:21:58:28 Nathaniel NATHANIEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49991961 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/6:21:58:28 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:21:58:28 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI85EC.tmp 2014/9/6:21:58:31 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/6:21:58:30 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/6:21:58:30 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:21:58:30 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI85EC.tmp 2014/9/6:21:58:30 Nathaniel NATHANIEL-PC Launch 2014/9/6:21:58:30 Nathaniel NATHANIEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6... 2014/9/6:21:58:30 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI85EC.tmp\Setup\InventorUI.dll 2014/9/6:21:58:30 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:21:58:31 Nathaniel NATHANIEL-PC PageOpen LaunchDialog 2014/9/6:21:58:40 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI85EC.tmp\Setup\InventorUI.dll 2014/9/6:21:58:40 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:21:58:40 Nathaniel NATHANIEL-PC Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/6:21:58:40 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI85EC.tmp\Setup\InventorUI.dll 2014/9/6:21:58:40 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:21:58:40 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2014/9/6:21:58:40 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC PageOpen LicenseDialog 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC PageOpen ProductInfoDialog 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC PageOpen InventorFlavorSelectionDialog 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==DefaultLanguage: en-us 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==InstallName: INVENTOR 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==ProductName: Autodesk Inventor 2015 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==DisplayName: AutodeskĀ® InventorĀ® 2015 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==DeploymentName: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==SetupTitle: Autodesk Inventor 2015 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==ConfigTransform: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==ExeParams: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4} 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==SupportLink: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==InfotainmentLink: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==MsiFileName: inventor.msi 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==AdminImageConfigName: Imgx64 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==AdminImageRoot: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==GetBaseDeploymentName: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==DeploymentLocation: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==InstallDeploymentShortcut: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==ModifyDeploymentShortcut: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==SetupLockType: 2 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==SetupNetworkType: 1 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==SystemLocale: 1033 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==EvalMsiFilePath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI85EC.tmp\SetupRes\eval.msi 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==InstallLogPath: C:\Users\NATHAN~1\AppData\Local\Temp\Inventor2015Install.log 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==ConfigFile: C:\Users\NATHAN~1\AppData\Local\Temp\_AI85EC.tmp\Setup.ini 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==SetupPath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI85EC.tmp\ 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==NetworkLogPath: 2014/9/6:21:58:56 Nathaniel NATHANIEL-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015 2014/9/6:21:59:07 Nathaniel NATHANIEL-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2014/9/6:21:59:07 Nathaniel NATHANIEL-PC PageOpen ProductSelectionDialog2 2014/9/6:21:59:41 Nathaniel NATHANIEL-PC PageOpen FullProgressDialog 2014/9/6:21:59:42 Nathaniel NATHANIEL-PC Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST... 2014/9/6:21:59:42 Nathaniel NATHANIEL-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\NATHAN~1\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/9/6:21:59:52 Nathaniel NATHANIEL-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603 2014/9/6:21:59:53 Nathaniel NATHANIEL-PC PageOpen InstallCompleteDialog 2014/9/6:22:00:36 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/6:22:11:10 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/6:22:11:10 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:22:11:10 Nathaniel NATHANIEL-PC Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US 2014/9/6:22:11:10 Nathaniel NATHANIEL-PC Launch 2014/9/6:22:11:10 Nathaniel NATHANIEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49991961 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/6:22:11:10 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:22:11:10 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI26EB.tmp 2014/9/6:22:11:13 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/6:22:11:12 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/6:22:11:12 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/6:22:11:12 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI26EB.tmp 2014/9/6:22:11:12 Nathaniel NATHANIEL-PC Launch 2014/9/6:22:11:12 Nathaniel NATHANIEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6... 2014/9/6:22:11:12 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI26EB.tmp\Setup\InventorUI.dll 2014/9/6:22:11:12 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:22:11:13 Nathaniel NATHANIEL-PC PageOpen LaunchDialog 2014/9/6:22:11:19 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI26EB.tmp\Setup\InventorUI.dll 2014/9/6:22:11:19 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:22:11:19 Nathaniel NATHANIEL-PC Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/6:22:11:19 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI26EB.tmp\Setup\InventorUI.dll 2014/9/6:22:11:19 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/6:22:11:19 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2014/9/6:22:11:19 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC PageOpen LicenseDialog 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC PageOpen ProductInfoDialog 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC PageOpen InventorFlavorSelectionDialog 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==DefaultLanguage: en-us 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==InstallName: INVENTOR 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==ProductName: Autodesk Inventor 2015 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==DisplayName: AutodeskĀ® InventorĀ® 2015 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==DeploymentName: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==SetupTitle: Autodesk Inventor 2015 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==ConfigTransform: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==ExeParams: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4} 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==SupportLink: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==InfotainmentLink: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==MsiFileName: inventor.msi 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==AdminImageConfigName: Imgx64 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==AdminImageRoot: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==GetBaseDeploymentName: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==DeploymentLocation: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==InstallDeploymentShortcut: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==ModifyDeploymentShortcut: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==SetupLockType: 2 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==SetupNetworkType: 1 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==SystemLocale: 1033 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==EvalMsiFilePath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI26EB.tmp\SetupRes\eval.msi 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==InstallLogPath: C:\Users\NATHAN~1\AppData\Local\Temp\Inventor2015Install.log 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==ConfigFile: C:\Users\NATHAN~1\AppData\Local\Temp\_AI26EB.tmp\Setup.ini 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==SetupPath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI26EB.tmp\ 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==NetworkLogPath: 2014/9/6:22:11:35 Nathaniel NATHANIEL-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015 2014/9/6:22:11:37 Nathaniel NATHANIEL-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2014/9/6:22:11:37 Nathaniel NATHANIEL-PC PageOpen ProductSelectionDialog2 2014/9/6:22:11:51 Nathaniel NATHANIEL-PC PageOpen FullProgressDialog 2014/9/6:22:11:51 Nathaniel NATHANIEL-PC Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST... 2014/9/6:22:11:51 Nathaniel NATHANIEL-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\NATHAN~1\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/9/6:22:12:00 Nathaniel NATHANIEL-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603 2014/9/6:22:12:00 Nathaniel NATHANIEL-PC PageOpen InstallCompleteDialog 2014/9/6:22:47:01 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/7:09:40:40 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/7:09:40:40 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:40:40 Nathaniel NATHANIEL-PC Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US 2014/9/7:09:40:40 Nathaniel NATHANIEL-PC Launch 2014/9/7:09:40:40 Nathaniel NATHANIEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49991961 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/7:09:40:40 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:40:40 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI8D51.tmp 2014/9/7:09:40:45 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/7:09:40:42 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/7:09:40:42 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:40:42 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI8D51.tmp 2014/9/7:09:40:42 Nathaniel NATHANIEL-PC Launch 2014/9/7:09:40:44 Nathaniel NATHANIEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6... 2014/9/7:09:40:44 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI8D51.tmp\Setup\InventorUI.dll 2014/9/7:09:40:44 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:40:45 Nathaniel NATHANIEL-PC PageOpen LaunchDialog 2014/9/7:09:40:55 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI8D51.tmp\Setup\InventorUI.dll 2014/9/7:09:40:55 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:40:55 Nathaniel NATHANIEL-PC Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/7:09:40:55 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI8D51.tmp\Setup\InventorUI.dll 2014/9/7:09:40:55 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:40:55 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2014/9/7:09:40:55 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC PageOpen LicenseDialog 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC PageOpen ProductInfoDialog 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC PageOpen InventorFlavorSelectionDialog 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==DefaultLanguage: en-us 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==InstallName: INVENTOR 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==ProductName: Autodesk Inventor 2015 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==DisplayName: AutodeskĀ® InventorĀ® 2015 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==DeploymentName: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==SetupTitle: Autodesk Inventor 2015 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==ConfigTransform: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==ExeParams: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4} 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==SupportLink: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==InfotainmentLink: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==MsiFileName: inventor.msi 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==AdminImageConfigName: Imgx64 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==AdminImageRoot: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==GetBaseDeploymentName: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==DeploymentLocation: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==InstallDeploymentShortcut: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==ModifyDeploymentShortcut: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==SetupLockType: 2 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==SetupNetworkType: 1 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==SystemLocale: 1033 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==EvalMsiFilePath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI8D51.tmp\SetupRes\eval.msi 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==InstallLogPath: C:\Users\NATHAN~1\AppData\Local\Temp\Inventor2015Install.log 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==ConfigFile: C:\Users\NATHAN~1\AppData\Local\Temp\_AI8D51.tmp\Setup.ini 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==SetupPath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI8D51.tmp\ 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==NetworkLogPath: 2014/9/7:09:41:47 Nathaniel NATHANIEL-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015 2014/9/7:09:42:31 Nathaniel NATHANIEL-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2014/9/7:09:42:31 Nathaniel NATHANIEL-PC PageOpen ProductSelectionDialog2 2014/9/7:09:42:41 Nathaniel NATHANIEL-PC PageOpen FullProgressDialog 2014/9/7:09:42:41 Nathaniel NATHANIEL-PC Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST... 2014/9/7:09:42:41 Nathaniel NATHANIEL-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\NATHAN~1\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/9/7:09:42:53 Nathaniel NATHANIEL-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603 2014/9/7:09:42:56 Nathaniel NATHANIEL-PC PageOpen InstallCompleteDialog 2014/9/7:09:46:33 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/7:09:47:34 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/7:09:47:34 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:47:34 Nathaniel NATHANIEL-PC Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US 2014/9/7:09:47:34 Nathaniel NATHANIEL-PC Launch 2014/9/7:09:47:34 Nathaniel NATHANIEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49991961 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/7:09:47:34 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:47:34 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AIDEAB.tmp 2014/9/7:09:47:36 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/7:09:47:35 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/7:09:47:35 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:47:35 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AIDEAB.tmp 2014/9/7:09:47:35 Nathaniel NATHANIEL-PC Launch 2014/9/7:09:47:35 Nathaniel NATHANIEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6... 2014/9/7:09:47:35 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AIDEAB.tmp\Setup\InventorUI.dll 2014/9/7:09:47:35 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:47:35 Nathaniel NATHANIEL-PC PageOpen LaunchDialog 2014/9/7:09:47:40 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AIDEAB.tmp\Setup\InventorUI.dll 2014/9/7:09:47:40 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:47:40 Nathaniel NATHANIEL-PC Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/7:09:47:40 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AIDEAB.tmp\Setup\InventorUI.dll 2014/9/7:09:47:40 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:47:40 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2014/9/7:09:47:40 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC PageOpen LicenseDialog 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC PageOpen ProductInfoDialog 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC PageOpen InventorFlavorSelectionDialog 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==DefaultLanguage: en-us 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==InstallName: INVENTOR 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==ProductName: Autodesk Inventor 2015 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==DisplayName: AutodeskĀ® InventorĀ® 2015 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==DeploymentName: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==SetupTitle: Autodesk Inventor 2015 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==ConfigTransform: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==ExeParams: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4} 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==SupportLink: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==InfotainmentLink: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==MsiFileName: inventor.msi 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==AdminImageConfigName: Imgx64 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==AdminImageRoot: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==GetBaseDeploymentName: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==DeploymentLocation: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==InstallDeploymentShortcut: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==ModifyDeploymentShortcut: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==SetupLockType: 2 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==SetupNetworkType: 1 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==SystemLocale: 1033 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==EvalMsiFilePath: C:\Users\NATHAN~1\AppData\Local\Temp\_AIDEAB.tmp\SetupRes\eval.msi 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==InstallLogPath: C:\Users\NATHAN~1\AppData\Local\Temp\Inventor2015Install.log 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==ConfigFile: C:\Users\NATHAN~1\AppData\Local\Temp\_AIDEAB.tmp\Setup.ini 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==SetupPath: C:\Users\NATHAN~1\AppData\Local\Temp\_AIDEAB.tmp\ 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==NetworkLogPath: 2014/9/7:09:47:56 Nathaniel NATHANIEL-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015 2014/9/7:09:47:59 Nathaniel NATHANIEL-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2014/9/7:09:47:59 Nathaniel NATHANIEL-PC PageOpen ProductSelectionDialog2 2014/9/7:09:48:04 Nathaniel NATHANIEL-PC PageOpen FullProgressDialog 2014/9/7:09:48:04 Nathaniel NATHANIEL-PC Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST... 2014/9/7:09:48:04 Nathaniel NATHANIEL-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\NATHAN~1\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/9/7:09:48:12 Nathaniel NATHANIEL-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603 2014/9/7:09:48:12 Nathaniel NATHANIEL-PC PageOpen InstallCompleteDialog 2014/9/7:09:48:33 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/7:09:54:17 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/7:09:54:17 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:54:17 Nathaniel NATHANIEL-PC Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US 2014/9/7:09:54:17 Nathaniel NATHANIEL-PC Launch 2014/9/7:09:54:17 Nathaniel NATHANIEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49991961 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/7:09:54:17 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:54:17 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI5012.tmp 2014/9/7:09:54:22 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/7:09:54:19 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/7:09:54:19 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:09:54:19 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI5012.tmp 2014/9/7:09:54:19 Nathaniel NATHANIEL-PC Launch 2014/9/7:09:54:20 Nathaniel NATHANIEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6... 2014/9/7:09:54:21 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI5012.tmp\Setup\InventorUI.dll 2014/9/7:09:54:21 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:54:22 Nathaniel NATHANIEL-PC PageOpen LaunchDialog 2014/9/7:09:54:36 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI5012.tmp\Setup\InventorUI.dll 2014/9/7:09:54:36 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:54:36 Nathaniel NATHANIEL-PC Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/7:09:54:36 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI5012.tmp\Setup\InventorUI.dll 2014/9/7:09:54:36 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:09:54:36 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2014/9/7:09:54:36 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC PageOpen LicenseDialog 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC PageOpen ProductInfoDialog 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC PageOpen InventorFlavorSelectionDialog 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==DefaultLanguage: en-us 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==InstallName: INVENTOR 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==ProductName: Autodesk Inventor 2015 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==DisplayName: AutodeskĀ® InventorĀ® 2015 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==DeploymentName: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==SetupTitle: Autodesk Inventor 2015 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==ConfigTransform: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==ExeParams: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4} 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==SupportLink: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==InfotainmentLink: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==MsiFileName: inventor.msi 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==AdminImageConfigName: Imgx64 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==AdminImageRoot: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==GetBaseDeploymentName: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==DeploymentLocation: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==InstallDeploymentShortcut: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==ModifyDeploymentShortcut: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==SetupLockType: 2 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==SetupNetworkType: 1 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==SystemLocale: 1033 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==EvalMsiFilePath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI5012.tmp\SetupRes\eval.msi 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==InstallLogPath: C:\Users\NATHAN~1\AppData\Local\Temp\Inventor2015Install.log 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==ConfigFile: C:\Users\NATHAN~1\AppData\Local\Temp\_AI5012.tmp\Setup.ini 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==SetupPath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI5012.tmp\ 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==NetworkLogPath: 2014/9/7:09:57:10 Nathaniel NATHANIEL-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015 2014/9/7:09:57:30 Nathaniel NATHANIEL-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2014/9/7:09:57:30 Nathaniel NATHANIEL-PC PageOpen ProductSelectionDialog2 2014/9/7:09:57:36 Nathaniel NATHANIEL-PC PageOpen FullProgressDialog 2014/9/7:09:57:36 Nathaniel NATHANIEL-PC Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST... 2014/9/7:09:57:36 Nathaniel NATHANIEL-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\NATHAN~1\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/9/7:09:57:50 Nathaniel NATHANIEL-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603 2014/9/7:09:57:52 Nathaniel NATHANIEL-PC PageOpen InstallCompleteDialog 2014/9/7:10:13:49 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/7:11:10:23 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/7:11:10:23 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:11:10:23 Nathaniel NATHANIEL-PC Current Directory C:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_wi_en-US 2014/9/7:11:10:23 Nathaniel NATHANIEL-PC Launch 2014/9/7:11:10:23 Nathaniel NATHANIEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_English_Win_64bit_R1_wi_... /SN 900-49991961 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/9/7:11:10:23 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:11:10:23 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI51D7.tmp 2014/9/7:11:11:08 Nathaniel NATHANIEL-PC === Setup ended === 2014/9/7:11:10:24 Nathaniel NATHANIEL-PC === Setup started on NATHANIEL-PC by Nathaniel === 2014/9/7:11:10:24 Nathaniel NATHANIEL-PC Path_Length: 155 2014/9/7:11:10:24 Nathaniel NATHANIEL-PC Current Directory C:\Users\NATHAN~1\AppData\Local\Temp\_AI51D7.tmp 2014/9/7:11:10:24 Nathaniel NATHANIEL-PC Launch 2014/9/7:11:11:07 Nathaniel NATHANIEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/SETUP_x6... 2014/9/7:11:11:07 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI51D7.tmp\Setup\InventorUI.dll 2014/9/7:11:11:07 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:11:11:08 Nathaniel NATHANIEL-PC PageOpen LaunchDialog 2014/9/7:11:12:22 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI51D7.tmp\Setup\InventorUI.dll 2014/9/7:11:12:22 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:11:12:22 Nathaniel NATHANIEL-PC Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/7:11:12:22 Nathaniel NATHANIEL-PC Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\NATHAN~1\AppData\Local\Temp\_AI51D7.tmp\Setup\InventorUI.dll 2014/9/7:11:12:22 Nathaniel NATHANIEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/9/7:11:12:22 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2014/9/7:11:12:22 Nathaniel NATHANIEL-PC Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC PageOpen LicenseDialog 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC PageOpen ProductInfoDialog 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC PageOpen InventorFlavorSelectionDialog 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==DefaultLanguage: en-us 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==InstallName: INVENTOR 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==ProductName: Autodesk Inventor 2015 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==DisplayName: AutodeskĀ® InventorĀ® 2015 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==DeploymentName: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==SetupTitle: Autodesk Inventor 2015 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==ConfigTransform: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==ExeParams: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4} 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==SupportLink: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==InfotainmentLink: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==MsiFileName: inventor.msi 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==AdminImageConfigName: Imgx64 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==AdminImageRoot: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==GetBaseDeploymentName: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==DeploymentLocation: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==InstallDeploymentShortcut: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==ModifyDeploymentShortcut: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==SetupLockType: 2 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==SetupNetworkType: 1 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==SystemLocale: 1033 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==EvalMsiFilePath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI51D7.tmp\SetupRes\eval.msi 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==InstallLogPath: C:\Users\NATHAN~1\AppData\Local\Temp\Inventor2015Install.log 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==ConfigFile: C:\Users\NATHAN~1\AppData\Local\Temp\_AI51D7.tmp\Setup.ini 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==SetupPath: C:\Users\NATHAN~1\AppData\Local\Temp\_AI51D7.tmp\ 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==NetworkLogPath: 2014/9/7:11:13:06 Nathaniel NATHANIEL-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015 2014/9/7:11:14:00 Nathaniel NATHANIEL-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2014/9/7:11:14:00 Nathaniel NATHANIEL-PC PageOpen ProductSelectionDialog2 2014/9/7:11:14:11 Nathaniel NATHANIEL-PC PageOpen FullProgressDialog 2014/9/7:11:14:12 Nathaniel NATHANIEL-PC Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{A883E590-ED89-4D5C-BAA3-C44B3BCDFBD1}/VCREDIST... 2014/9/7:11:14:12 Nathaniel NATHANIEL-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\NATHAN~1\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/9/7:11:14:20 Nathaniel NATHANIEL-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
